Power Steering Conversion Mid-year
Old Apr 3, 2008 | 12:59 PM
red65Michigan's Avatar
red65Michigan
Default Power Steering Conversion Mid-year
Purchased PS conversion kit for 65 after doing research on the forum from all the folks. This is the stock conversion, not the steeroids. I was expecting some kind of general step by step instruction sheet to read thru before I jumped into the "fire" also to make sure I had every piece I needed before discovering a mistake in the kit.
Read thru the FAQ lists provided by the forum and checked out Barry's website. Can someone direct me to a place with an instruction sheet.... photos / diagrams would be nice also.
Mike
Old Apr 3, 2008 | 01:40 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Mike,
The best thing to use for instructions is the assembly manual. Go the N40 section under the options index and you should see just about everything you need to install the kit.
There are some help instructions on our site for making sure you have the power steering hose’s installed correct (they make an X).
If you have a problem during install, just email me at willcoxcustomerservice@willcoxcorvette.c om I’ve done quite a few of these conversions so it won’t be a problem.
Willcox
Old Apr 3, 2008 | 05:43 PM
RDaddi's Avatar
RDaddi
Default Steering
Corvette Fever did a great step by step photo with instructions article" Steering Simplification" by Andy Bolig. If you can't find the link send me an e-mail address and I will scan the article to you. I used this for my conversion on a 65 vert. Bob
To Power Steering Conversion Mid-year
