Shift light and bracket installed
Old Apr 5, 2008 | 04:02 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default Shift light and bracket installed
No holes drilled in car.
Bracket is a modified 1.75" clamp on shaft collar,a nd piece of 1/2" aluminum round bar. I had to thin the collar down to 1/2" from 3/4" wide and drill and tap a 1/4"-20 hole for the aluminum extension bar
Unobtrusive, out of the way,and very visible.
Doug
Old Apr 5, 2008 | 04:42 PM
KyleDallas's Avatar
KyleDallas
Very clean.... nice craftsmanship Doug..
Old Apr 13, 2008 | 11:02 PM
c160go's Avatar
c160go
Cruising
Default what mfg shift light?
Doug, really like your shift light install, have been wondering how to do same thing, now have a solution. Just one question what mfg is the shift light you are using?.
Old Apr 14, 2008 | 01:40 AM
AZDoug's Avatar
AZDoug
Raptor Performance. Someplace in NC.
Uses DIP switches for RPM, no pills. Smallest I found also.
Doug
To Shift light and bracket installed
