u-joints
Old Apr 7, 2008 | 06:32 AM
VinceP's Avatar
VinceP
Default u-joints
I am replacing u-joints on my short shafts is there any thoughts between using joints with or without grease fitting .Thanks ....Vince
Old Apr 7, 2008 | 07:42 AM
covett's Avatar
covett
If you are going to have your car judged you will definitely lose points with grease fittings. also, not that you are going to beat on that drive line , good old made in the USA non greaseable u-joints are stronger
Old Apr 7, 2008 | 08:25 AM
vark_wso's Avatar
vark_wso
Vince
Spicer SP 5-785X for propeller shaft, and SP 5-799X for half shafts are the permanent lubed, non-greaseable USA replacement joints. Very reasonably priced.
To u-joints
