Under the dash
Also "found' while under the dash a brown waxy/cardboard capacitor about 2" long and about as wide as a finger. It is not connected to the harness but has black wire in each end with a brass male spade fitting. It is physically located on the outboard side of the dash frame to the left of the steering column.
Any ideas on either item?
Click on Corvette, then tech issues, scroll down to instruments and gauges. Look a the pictures supplied by Dave Zuberer on the wiring harness He has really good pics of each section with the labels.
Don
What type of bulb socket is on the end of that wire? The following odd bulbs are found:
1) Small diameter metal socket. Snaps into a special shield which mounts to the side of the cig lighter
2) Small diameter socket with rubber-ish outside. This snaps into the ignition switch
3) Small diamter metal socket. Snaps into a bullet-shaped shield with a funky clip on the bottom. This clip allows this bulb to clip under the clock at the 6 o'clock position, providing back lighting for the dash *****.
On that capacitor, as John said, that's for the brake switch.
Oh, there was no option for extra bulbs, however there are a few special cases:
1) 63-64 main instrument cluster has 2 fewer "grey wire" bulbs than a 65 and up. so if you have a 66 wiring harness but a 63 or 64 cluster, you would have 2 extra bulbs.
2) Factory A/C cars have a totally separate, 2 bulb wiring harness which clips at about the 8 and 4 pm locations around the clock skeleton, to provide back lighting for the A/C *****. This harness is a 2 wire harness that is bundeled together with a single female connector, which plugs into the fuse panel.
Jeff
Jeff
Also, thanks for ID'ing the capacitor (yes it does have the brass "flag" connectors) both ends are loose. Where did they connect? (Given I've had the car for 25 years and they've never been hooked up, I question the function of the capacitor.....)
Thanks of all the help guys, I'm going to eat another fistful of motrim and crawl back under the dash tomorrow!
Cheers n' Gears//Mike
Here's a post by JohnZ that shows the bulb shield, and in this photo you can see the slot on the clock housing where it clips.
http://forums.corvetteforum.com/show...82&postcount=6
BTW; after all the reinstall drama, the gauges aren't working correctly anyhow
Mike
