Side pipes
Old Apr 8, 2008 | 08:12 AM
196690's Avatar
196690
Default Side pipes
Are there any "tell tale" signs that a car came from the factory with side pipes?
Old Apr 8, 2008 | 08:32 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Yes. Check the outer frame on each side. If you see where brackets have been or are still there, then the car did not originally have side pipes. If there is no evidence of brackets, either it had sidepipes originally or someone did some real good work eliminating the evidence. Also, if the car is an AO Smith, it would not have had sidepipes.
Steve
Old Apr 8, 2008 | 08:55 AM
Vet65te's Avatar
Vet65te
The splash shields, which normally had a rubber strip stapled along one edge for cars with undercar exhaust, did not have them on cars with side exhaust since the pipe would run almost right up against them.
Old Apr 8, 2008 | 09:56 AM
66BlkBB's Avatar
66BlkBB
Mine is original side exhaust and it had the splash shields. Where did you get that information?? Not questioning it, just wondering. When I tore my car down to rebuild back in 1979 I had to remove the splash shields and the car had been not run or licensed since 1972. Makes me believe that the shields were stock.
Steve
Old Apr 8, 2008 | 10:14 AM
1Sweet66's Avatar
1Sweet66
There would be no evidence of ground straps to exhaust pipe on the trans cross member in radio equip cars also look for repo rear valance or exhaust pipe holes glassed in and evidence of muffler hanger straps/bolts on the rear frame section.
Old Apr 8, 2008 | 10:17 AM
macs65's Avatar
macs65
Any reason why an A.O.Smith bodied car would not have been optioned with S/P?????
Old Apr 8, 2008 | 10:23 AM
Hitch's Avatar
Hitch
Steve
Not that the splash shields would not be there, the staple holes and the rubber seals would not be there.
Old Apr 8, 2008 | 10:24 AM
Hitch's Avatar
Hitch
There are no documented cases of AOS cars ever having Side pipes.
Old Apr 8, 2008 | 10:30 AM
66BlkBB's Avatar
66BlkBB
My error, I misread the previous post about the splash shields. Also, didn't JohnZ indicate that the AO Smith plant was not tooled up to produce cars with sidepipes? At least that's what I got from some of his threads on the subject.
Steve
Old Apr 8, 2008 | 10:36 AM
ctjackster's Avatar
ctjackster
the "why" is explained well by JohnZ, who has a nice picture of the notching machine that was used to create the slight relief in the sill and sill reinforcement to provide assembly clearance for the U-nuts for the side cover attachments. They didn't have such a fixture at AO Smith.
Old Apr 8, 2008 | 10:50 AM
Vet65te's Avatar
Vet65te
Regarding the lack of those rubber seals on the splash shields, I think I read it in the NCRS 'Restorer Magazine' some years ago. I've owned only one 'factory original' side pipe car, a 66 350 horse Coupe, and after reading the Restorer found that the splash shields on that car were clean with no staples or rubber seals. They figured the rubber seal would get toasted laying up against the side exhaust pipe. Not sure if all the original side pipe cars came this way or the factory 'figured it out' sometime further into the production run.
To Side pipes
