Bubba fix or factory?
Either you are really young (under 50), or, I'm really showing my age (your guess).
This is (or was) a really common way to secure pressed-in rocker arm studs.
It is kind of generally accepted that cams with greater than a .450 lift can cause the stock pressed-in studs to pull out. Especially on engines that are frequently pushed hard.
So, we went to the local speed shop and bought a stud pin kit which consisted of 16 pins and a drill bit.
Drill through the stud boss and into the stud, then knock in the pin. You now had "pinned" studs. The option was screw-in studs. There was also a kit for those also (I still have some of both).
Soooooooooooooooooo, what did you do when the stud went bad (broke off or the threads became bad)? That was never considered as a possibility.
Someone probably pinned those studs 30-40yrs ago.
NOOOOOOOOOOOOOOOOOO, that is NOT a bubba fix. That was a genuinly common mod, sold by ALL the speed shops.
Now, is no one going to admit to remembering or doing this?????????????
Probably did 50 sets or more back in the old days. Had to remove the pins on a couple when the studs sheared off. Just remove the valve spring and valve and drive the roll pin out. Drive the new stud in, re-drill the stud and install a new pin. Back in business.
Rich
Grey hairs older than you at Creitz Automotive in Tulsa in the 50's were using used needle bearings out of U joints to pin the studs. GM during the year 62 went from non pinned to pinned studs on the 409 engines. They had also gone to a wilder cam with different exhaust pushrods during the time period.
Regards
There was never a FACTORY SB with pinned studs. Screw in studs? Yes, but not pinned!
Guess it was a pretty common mod back in the day?
Good to hear.
Thanks guys.
Doug
Some people drilled all the way through the boss, and some didn't. If the hole was drilled all the way through, then the pin could be knocked out much more easily if need be.
