C1-vs C-2
No AC necessary, I live in coastal California.
Today with synthetic oil, you could probably double the engine life to 300,000. And a Pertronix or other modern ignition would probably increase plug life 50-100%.
Only limiting factor today might be mileage vs. gas prices. I wrote my 'Vette off for business use for years, so 50% of all expenses were a write-off. I can still write it off today without even driving it as it's part of my company logo.
First, all of old Corvette convertibles leak when it rains. Some more, some less, but they all leak. You will get wet.
If the mechanicals are overhauled/replaced any car can be reliable. That being said, an old car will require more maintenance than a newer one.
The older cars will generally not ride as well as newer cars. They do not ride with trucks if you install radial tires. Select a size appropriate for the car on seven inch wide wheels; example, 205 75 15, possibly 215 75 15.
Everyone has an opinion on tires; pick your own with an eye for wet performance and ride.
You can install an A/C in a C1. That is not the end of it. To make it work well in "humid, trafficy and sometimes rainy Houston", you will need to do a lot of work to stop air leaks and add insulation.
So I will come down on the side of a Midyear coupe with A/C. If it were mine, I would also install a late model fuel injected engine with automatic overdrive; less maintenance, better fuel mileage.
All that, and I will continue to drive my 57. Drove 5500 miles last sumer, SACC National Convention, Bloomington, NCRS National Convention, Carlisle with no problems so the old ones can be reliable.
But I did get wet.
Verle
