1962 electrical problem
Old Apr 22, 2008 | 08:11 PM
magrag's Avatar
magrag
2017 C1 of the Year Finalist
Default 1962 electrical problem
I have had my 1962 Vette since 1980 and it has always had this problem ( The gas gauge needle jumps up about 1/4 of the gauge when the turn signals are on and even move when I press on the brake pedal.)
I have been working on turning this car into a Vetterod for the last 1 and 1/2 years and now that it is about 95% done I am making all the electrical connections and this same problem is still there!!!
I have cleaned all connections and grounds, but I do not have all of the ground straps on as I am not using a radio (just CD player).
Any suggestions would be greatly appreciated.
Thanks!!
Old Apr 22, 2008 | 08:42 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Here is your answer in the first 3-4 paragraphs:
http://www.vetteclub.org/technicalti...lGaugeTech.pdf
Old Apr 22, 2008 | 08:52 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Here is your answer in one sentence:
Run a new seperate 12 gauge ground wire from the fuel sender unit to the frame.
Doug
Old Apr 22, 2008 | 09:24 PM
Frankie the Fink
Army
I think after fighting the problem for 28 years this fella might want a bit more info on the cause of the problem Doug... I sure would.
Old Apr 23, 2008 | 01:41 AM
AZDoug's Avatar
AZDoug
I only solved his problem, you offered background.
Doug
Old Apr 23, 2008 | 08:32 AM
kenmo's Avatar
kenmo
Doug
Doing this fixed my similar problem....
Old Apr 23, 2008 | 04:48 PM
Last 62's Avatar
Last 62
My car has been doing that for at least 43 years. I think I'll just leave it alone.
Jim
Old Apr 23, 2008 | 07:42 PM
magrag's Avatar
magrag
Thanks for the help I will try it soon and post my results.
Thanks again
Old Apr 24, 2008 | 08:10 PM
magrag's Avatar
magrag
Default Good news and Bad on my 62 gas gauge bouncing
After reading the solutions you guys gave me it started to sound familar and sure enough when I removed the tank cover there was the extra ground wire I installed about 6 months ago when I wired up the rear half. So I followed this wire found and the end was in the drivers side kick panel. Screwed it down and now the gauge only bounces about an 1/8 of an inch much better!!!!! But it still bounces. So I added another ground from sender to frame no difference!!! Next I ran a jumper from the sender to the - battery terminal. Still bounces!!
Any suggestion now or should I just be happy witha little bounce?!?!?!
Thanks for all your help!!!!
Old Apr 24, 2008 | 08:55 PM
Frankie the Fink
Army
I too get a small bounce after applying the extra ground to my '61 - but the gauge is usable now so I'll live with it - you should prob do the same. This may have been as good as it ever was even when the cars were new.
Old Apr 24, 2008 | 09:17 PM
TopLess62's Avatar
TopLess62
Doug
CRAP!!!! I wish you had told me this YESTERDAY befor I put my tank cover back on with new dumdum and put my seats back in!!!!
Old Apr 24, 2008 | 09:20 PM
Frankie the Fink
Army
You may not have the problem Pete. I'd test drive it before I opened things back up.
Old Apr 24, 2008 | 09:29 PM
TopLess62's Avatar
TopLess62
Oh, I have it alright!!! I always have and after my maiden voyage today, I still have it!!!
Old Apr 24, 2008 | 09:44 PM
Frankie the Fink
Army
Went through the same drill - after replacing my faulty fuel sending unit and 'buttoning up the patient' I find out the gauge is whacky and had to break everything open again and add the ground wire. Had to open it again a THIRD time when I found out later that my drain tube from my gas cap filler area was missing ! All within a couple of months.
Bite the bullet and do it and move on or it will bug you every time you drive off.
Old Apr 25, 2008 | 12:27 PM
AZDoug's Avatar
AZDoug
May i posit that you now have an improved ground, but you don't have a good ground.
Good ground: soldered terminals, not just crimped, clean both surfaces to fresh bright metal where the terminals attach to the sending unit screw and the frame.
It also helps to amke sure the rest of your grounds are good, if your frame to battery/frame to engine ground is bad, you still don't have a good ground.
I grounded the snot out of my car when i had the engine out last time.
Doug
Old Apr 25, 2008 | 12:56 PM
Jims66's Avatar
Jims66
I too have "grounded the snot" out of mine as well. I've put multiple extra grounds along with retaining the stock ones. You can never have too many groung wires. Someone told me a long time ago that most electrical problems are Grounding related.
Old Apr 26, 2008 | 06:30 AM
TopLess62's Avatar
TopLess62
The part that ticks me off is that I cleaned EVERYTHING up very nicely and even replaced my complete wiring harness - albeit a few years ago now. When I did the wiring, I added several new grounds that were not factory.
Old Apr 26, 2008 | 08:02 AM
babylonvette's Avatar
babylonvette
on later model cars[ 70/80,s ] they use a strap that has teeth[jaws] it is about 2'' long it clamps on the fuel line where the lines go together from the tank to the chassis it is a 2 second fix it is avaible thru parts houses and wrecking yarks
Old Apr 26, 2008 | 09:11 PM
magrag's Avatar
magrag
Thanks to all that have replied to my problem.
The good news is that after running a second ground to the frame (That makes 2 extra ground wires) my needle moves so little that I can hardly see it move when turn signals and brakes at applied.
Hope this might help others.
Thanks again
To 1962 electrical problem
