From: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
It appears to be the result of some misalignment when they were worked on. Also, look at the front left bumper position, sure looks a little off. I'd look closely at the whole undercarriage in that area to see what might be the result off some damage.
C2 headlights line up perfectly when properly installed and adjusted - in a no hit body that is
I see what may be a fat shim between the left bumper end and the front of the fender. Any shims go behind the glass. Looks to be some issues with the radiator support and/or the frame.
My 64 lined up perfectly after a few adjustments. This car looks like it may have taken a hit on the left side at some point and the repair may not have been aligned properly. Approach with caution, and look carefully. Open the hood and try to get a peak at the underside of the headlamp panel (use a small hand mirror) and look for evidence of a repair. Good luck, Pilot Dan
I agree, that left one is pretty bad, but I dont agree with the last statement. They seldom ever lighned up perfectly from the factory. Most had a wide gap on the inside and a narrow on the outside.
