Mine is 68-C
Looks like mine came out of a 68
I took my post down, because it was wrong (I do recall the square boxed ink stamp on mine, but that isn't the date code, I don't think:
I have a vague recollection that it says something like 18 CT in that box, perhaps an inspection mark. The date is stamped (not ink stamped tho), as I now recall, in a two-digit format, and yes, a letter for the month
I bet yours was simply replaced in 1968, at the dealer, who used a 68-dated rad.
I have a vague recollection that it says something like 18 CT in that box, perhaps an inspection mark. The date is stamped, as I now recall, in a two-digit format, and yes, a letter for the month
Yeah my date code is stamped into the radiator below the part number but I think you are probably still right about the date decipher.
The "16 CT" ink stamp was found on most mid year aluminum rads.
Your correct on the date stamping. This is "stamped" ( embossed ) into the top of the rad with year and month. Your 68-C is a 1968 March radiator. A= Jan, B= Feb......
The 3155316 was the part number for a small block, manual trans aluminum rad.
OK so I'm a little slow on the post button and I see that JohnZ addressed the date already.
Reason: not paying attention!
