Distributor rebuild
Old Apr 25, 2008 | 06:52 AM
roger newman's Avatar
roger newman
Default Distributor rebuild
I am in the process of rebuilding my distributor.
The lubrication for the upper shaft bushing has me a bit confused.
As I took everything apart the stuff under the plastic washer looked
something like oiled sawdust or Bubba's left over chewing tobacco.
What should I use for lubrication?
Old Apr 25, 2008 | 07:15 AM
BarryK's Avatar
BarryK
According to Dave Fiedler, who is very well known for his distributor repairs/restorations:
Repack the upper oil well (cavity surrounding upper bearing) with an oil absorbent material; a folded 3”x 3” piece of gauze is suitable.
Saturate the packing with oil (20wt. non-detergent motor oil is preferred). Note: Due to contamination, I do not attempt to use the saw dust like material that was originally packed in the well.
Install a new plastic seal (still available from GM under part number 1950569 for 10-pack) in the counterbore above the oil well and then position the felt washer on top of the seal. Saturate the felt with 20wt. oil.
Old Apr 25, 2008 | 07:36 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
A 3x3 piece of gause????????? REALLY? Now I haven't heard that one before. But for years I have wondered what was suitable to use to replace that packing. Actually, I've been packing my distributors with heavy chassis grease. So far, no problems. But on the other hand, I haven't found anyone to dispute the use of using heavy grease.
How about an opinion from Lars? Or anyone else?
Old Apr 25, 2008 | 12:10 PM
67L36Driver's Avatar
67L36Driver
Actually I think fine sawdust would work better than gause.
I salvaged the 'packing' material on the last one I did. Added more from another junk dist. Oiled it with some chainsaw bar & chain oil.
Old Apr 25, 2008 | 06:32 PM
magicv8's Avatar
magicv8
I use grease too.
Lots of miles with no problems, but then I have a roller bearing on my tach gear and a bronze thrust washer (button) on the nose end on the tach gear to keep the temp of the distributor low. Before I did that the distributor got hot.
Old Apr 25, 2008 | 06:38 PM
BarryK's Avatar
BarryK
hey, I was just passing on the info as I found it........ Dave has a good reputation for distributor repair/restoration so I'd have no reason to doubt his method but as always there are others ways that work also.
If interested, here is a link to his own article on restoring '62-'72 tach drive distributors and where he mentions the gauze.
http://www.tispecialty.com/articles/article6.htm
Old Apr 26, 2008 | 12:01 AM
wilbur's Avatar
wilbur
Hey Barry, Thanks for the link !
To Distributor rebuild
