Carpet Installation question...
Old Apr 27, 2008 | 12:43 PM
wow's Avatar
wow
Default Carpet Installation question...
OK, I got all of my old carpet out and the mess cleaned up. I am installing a heat barrier, then the jute with the rubber backing then the carpet. My question is, what all do I apply adhesive to? Do I adhesive the barrier to the floor, the jute to the barrier and the carpet to the jute...or do I just need to adhesive the barrier to the floor and the weight of the other two will hold them down? Also, how did anyone else mark the holes for the seats, sill plates, etc.? Did you pre-punch with an icepick, screwdriver...what worked for you? Thanks for any help and advice you may have...Nick
Old Apr 27, 2008 | 09:48 PM
RandyFM2499's Avatar
RandyFM2499
Navigator
Nick,
You really shouldn't need to use too much glue. I recently did my '63 carpet with a heat shield and I tacked down the heat barrier with adhesive and let the carpet set on top of that. The sill plates and seats do a good job of holding everything in place. In the back I just tacked the carpet together on the wheel wells. As for locating the cut outs, I used an ice pick and an exacto knife for the small cuts. Good Luck.
Old Apr 28, 2008 | 03:49 AM
ghostrider20's Avatar
ghostrider20
By a heat gun or a hot blow dryer. Heat the carpet up in the corners and curves. A small 2X4 and rubber hammer work well for fitting as well. Also, before you start, if the pieces have been folded or stored and have a crease in them, lay then out on the floor and weight them down for a few days.
Mark
Old Apr 28, 2008 | 05:15 AM
67pete's Avatar
67pete
For the screw hole locations, just put in the screws before you lay the jute and carpet. Don't let them stick up too high or the pading won't lay flat......
Old May 1, 2008 | 11:12 AM
wow's Avatar
wow
67Pete, not to appear any dumber than I am, but if you put the screws in first, then glued the jute and carpet, what method did you use to relocate the screws...did you pre-punch the carpet too? Thanks, Nick
Old May 1, 2008 | 12:10 PM
5thvet's Avatar
5thvet
I pre-punched all the holes by heating up a phillips head screw driver ( or a punch) and actually burning a hole which kind of also serves as a seal around the edges. Don't use a drill or you will unravel the carpet and have a mess.
Don
Old May 1, 2008 | 12:15 PM
ratpack1968's Avatar
ratpack1968
a cheap soldering iron works well for punching holes too....
Old May 1, 2008 | 01:02 PM
67pete's Avatar
67pete
No, with the screws, with a sharp point inplace of the hex head installed, they will give you the exact location where the holes need to be. Now I've always used a carpet knife and a hefty scissor / shear for trimming, but a soldering iron sounds like it would work also.
Old May 1, 2008 | 02:53 PM
highschool67's Avatar
highschool67
Don
Like hot knife through butter.
Old May 1, 2008 | 03:12 PM
ren's Avatar
ren
I used residential capet paste. The spray stuff just didn't cut it. I didn't use much, but the paste stayed in place. For the sills, I cut twi pieces of 1X2 and used wood clamps to hold them in place. Re: the hole, I used an ice pick and did it one layer at a time. Good Luck.
Old May 1, 2008 | 04:37 PM
GaryS's Avatar
GaryS
This is what I did when I replaced the carpet in my 66. After a tedious carpet installation, I wanted the seat belts in. I located the holes using a thin pick. Once I found them, I used a pencil point soldering iron to burn a hole in the carpet. Since the carpet is nylon, this did the task of locating the holes as well as sealing the the nylon fibers.
Gary
To Carpet Installation question...
