column question
Old Apr 29, 2008 | 04:06 PM
6T3's Avatar
6T3
Default column question
are column collars different for 63 and 65-67?
If so, I need a 65-67 one, anyone have one for sale?
I have a 65-67 dash in a 63 car and I have a gap above the collar, I want to get rid of this gap.
Thanks a bunch...
Old Apr 29, 2008 | 09:42 PM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
6T3,
Since no one else jumped in here, I'll give this a try. I don't have a collar for you but I'm thinking this archived thread may help you.
http://forums.corvetteforum.com/show...teering+Column
Basically, your car probably had the steering column out in its life. The above thread post by JohnZ gives the correct order of assembly back into the car. That collar, if there is no difference between years, should then fill that gap correctly.
Hope this helps.
Regards,
Jim
Old Apr 29, 2008 | 09:51 PM
Dougs63's Avatar
Dougs63
2018 C4 of Year Finalist
2016 C4 of Year Finalist
2015 C4 of Year Finalist
Short answer to your question is yes - the '63 collar is different to fit into the rounded cut-out on a '63-only dash cluster.
A '63 steering collar will not properly fit your later model cluster. I believe the steering collar for all C-2's are repro'd. so you can easily get the correct one for your cluster.
--Doug
Old May 5, 2008 | 12:57 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
I have a 64 dash in my 63. I am going to use a 64 collar and I think it will cover the gap.
To column question
