So i started to assemle the 327 chevy corvette block and the pistons stick up about .015 to .020 above the deck. The gasket i have is .039 thick. If there isnt any interference with the heads will i be ok running these gaskets since the engine will only have a .019" squench?? I think technically it is suppose to be around .030-.035 from the advice i have received on this forum
Hey, wait a minute ! You sure you are not checking it with piston rock ? You need to measure that right at the wrist pin centerline. Either that or someone decked the heck out of it.
If you are assembling this engine; please buy the book on How to Rebuild the Small-Block Chevrolet by Larry Atherton and Larry Schreib.
Please refer to chapter 7 pre-assembly, page 106. You must grasp and calculate the relationship of your piston to deck height with the head and valvetrain that you are using, to establish the optimum gasket thickness along with calculating your compression ratio. This book and this forum will answer all of your questions. No guesswork!
brgds
rene
I dont have that one, but a lot of others.
I've been reading up online and it appears that my feeler gauge method should give me an accurate measurement considering that the piston tops are sticking up past the deck. If they were down inside the bores i would need to use another method, but they are not.
Yes the block has been decked to hell and back. Long long story that i really dont feel like typing again.
If my measurements are correct i will need a thick head gasket.
I'm getting a measurement of .030 at the top of the piston and .025 at the bottom-wow!
So, i assume i will need around a .060 head gasket.
After i get this all figured out should i use
a. copper
What will a .060 gasket do to your compression ratio? Did you recalc your compression ratio with this new piston/deck height?
If you're going to do it, I think you might need to enter -.030 into the calculator. As a point of reference, my piston/deck height was from .042 to .032 IN THE HOLE.
A quick calc tells me your heads combustion chamber volume should be closer to 70 than 60. I don't remember what you're going to run but it shouldn't be stock double humps unless they have had some work done to them.
You will need a gasket that's at least .060". The reason your getting a different reading from the top to the bottom is the piston is rocking In the bore. You can rock it back and forth until the readings are the same form top to bottom and that will be a closer way to get a ballpark reading. I see your using a roller cam. You need to mock up the assembly and clay the tops of your pistons to check for adequate valve to piston clearance.
You see the straight line at the valve relief pockets? That's where you should be measuring deck height. You SHOULD be using a depth mike, but will be close with feelers guage. The proper way to fix this is to cut the tops of the pistons. BUT, you can get away with a thicker head gasket. It's also a good idea to check your valve to piston clearance.
You can lay steel machinist rule on edge across the top of the piston where "Pop" said to measure and take your readings with your feeler gauge.
With the deck cut to sh*t, and I recall the heads being milled too, the .060" Fel Pros will help get your head to intake geometry back where it belongs, hopefully allowing you to get a good intake gasket seal. If not, then you are looking at milling your intake to fit. Granted, milling off the piston tops is the "correct" way to fix it but the thicker gasket will be fine.
As stated, really check your valve clearance to those pistons with some clay since you are using a higher lift roller. You are going to have to use a solid roller lifter or open one of those hydraulics up and shim it so it doesn't compress.
This greatly explains why your first pistons were cut so much, to get them into the block. With the measurements you have given, your block has been decked .055"-.060", I'm surprised you were even able to get the intake to seal to the heads very well.
Felpro used to have spacers; I think they were called Head Savers. They would restore deck to head quench ability if the block was decked and the heads were milled. Do your math. Lots of options.
As Scott mentioned; intake manifold may also require proper adjustment.
brgds
rene
I see roller lifters in that baby, how much lift do you have and have you given any thought to piston to valve clearence??? The exhaust will be the one that hits, it chases the piston down the bore on the exhaust stroke. You bee a bare minimum of .080 and .100 would be better.
