Engine Hoist
Old May 4, 2008 | 08:33 AM
Brumbach's Avatar
Brumbach
Default Engine Hoist
Can you recommend a engine hoist? Probably won't use it more than twice so I'm in the market for a used one. I'd think a load leveler will be needed to handle sbc w/tranny attached.
Thanks,
Old May 4, 2008 | 12:02 PM
NEVERL8's Avatar
NEVERL8
In the same boat as you so I rented one. One day for engine out, one for engine in. $50 for the two days. I did not want to have an engine hoist taking up space since I do not plan on doing engine swaps on a regular basis. I did buy a load leveler from Pep Boys. Worked very well.
Old May 4, 2008 | 12:17 PM
ironarms's Avatar
ironarms
St. Jude Donor '05-'08-'09
i bought one form the local harbor freight , the legs fold up when not in use , it was a little over 100.00 with the discount coupon i had
Old May 4, 2008 | 09:45 PM
chris ritchie's Avatar
chris ritchie
You can buy them for about twice the daily rental cost. So, if you screw up, and need the hoist for more than 1 day, you're better off buying. Look at Pep Boys, Harbor Freight, and Northern Tool. Go to car show/swap meets. Those cheap Made in China ones work pretty good. Maybe you can sell it on Craigs List after you finish with it. The leveler jobby is a must have.
Old May 4, 2008 | 10:52 PM
mechron's Avatar
mechron
i bought one too, just didn't make sense to rent. i fold up the legs and store it in the shed when not in use. once you have one you will find other uses for it. i have a big roll around workbench with removable top and am doing a body-off C2 resto, i took the top off my workbench and lifted the bare frame up and set it on the workbench to do the plumbing and front/rear suspension. IT WAS GREAT doing all that stuff at workbench hight.
To Engine Hoist
