dash harnes install
Search the forum, this has been covered numerous times.
For starters, go to BarryK's tech pages web site for articles by JohnZ, DaveZ, and Bill Schroeder
http://lbfun.com/Corvette/Tech/vette...ster%20pt1.pdf
and
http://lbfun.com/Corvette/Tech/vette...ster%20pt2.pdf
and
http://lbfun.com/Corvette/Tech/vette...%20removal.pdf
and
http://lbfun.com/Corvette/Tech/vette...%20labeled.pdf
and finally
and
and
and
and finally
The best $12 you'll ever spend if you're doing any wiring on your car. Not a difficult job, just tedious.
Paul
and
and
and
and finally
This is exactly what I used too and it wasn't really that bad. The first time you do it , it is a little scary so it takes longer but if I were to do it again it would probably be done in a day. Last time it took about three to four days combined. I took loads of pictures and sketched where things went. Everything I took off I put in a baggie with a note as to what it was and where it went. Seems **** but trust me you'll forget when you are starting to reassemble everything. Make sure you get those tools recommended for the ***** and the 6" pieces to replace the screws from the cluster to slide it out. Good luck
Don
