1964 engine configuraton question
Old May 5, 2008 | 03:13 PM
cmprint's Avatar
cmprint
Default 1964 engine configuraton question
Can u bolt on a Aluminum 365 intake on a 300 hp block, do u have to change heads or anything else?
Will it still run as well as the cast iron intake?
MIKE
Old May 5, 2008 | 03:15 PM
LB66383's Avatar
LB66383
It will fit just fine. You may notice a slight increase in performance, or you may not. Are you also changing the carb?
Old May 5, 2008 | 05:05 PM
cmprint's Avatar
cmprint
I am keeping the original carb that is rebuilt.
And original heads.
Old May 5, 2008 | 05:36 PM
Rob-classof'64's Avatar
Rob-classof'64
Then why change the intake? Seriously, it won't make magic with the old carb. You need the appropriate Holley to get some improved result.
Back in the 60's we called this change (intake and carb) the 325hp-327.
Based on nothing more than speculation and teen optomism, but we thought they ran better.
Rob
Old May 5, 2008 | 05:38 PM
ceastham1's Avatar
ceastham1
St. Jude Donor '10-'11-'12-'13-'14-'15-'16
go to alum head if changing carb ...
Old May 5, 2008 | 09:15 PM
JohnZ's Avatar
JohnZ
And original heads.
The original carb is a Carter AFB - it won't fit on the aluminum 365hp intake - it only accepts a Holley.
Old May 6, 2008 | 09:23 AM
cmprint's Avatar
cmprint
Thanks for all the input.
Maybe I just leave well enough alone.
To 1964 engine configuraton question
