Water Pump question....
Old May 6, 2008 | 06:34 PM
macdarren's Avatar
macdarren
Default Water Pump question....
I was wondering.....is there any way to determine if a water pump is original....if so is there some point in keeping an original unit?
I have owned my car for a long time and it was a pretty original driver when I bought it...and while I am not a stickler for originality I do try to not make any changes to the car that can't be undone. I also try to keep any original parts that I remove.
Well I am moving and going through all my old parts. I have from time to time changed out the water pump and I have several, one that might be the original. If there is some way to identify it from the rest I will hang on to it. Maybe get it rebuilt and sell with the car or sell to someone that needs a period replacement. If they is no way to ID it or there is no big reason to keep it then I will just get rid of the whole collection.
Darren
P.S. this is a 1965 365hp car
Old May 6, 2008 | 10:06 PM
magicv8's Avatar
magicv8
water pump housings have a date code cast into them. IMO the date should precede the engine assembly date by a month or so. If you are having the car judged they will allow more than that - probably up to 6 months
Old May 7, 2008 | 12:13 AM
65 vette dude's Avatar
65 vette dude
The correct pump for your car is the 326 pump. It has the 1/2 inch bypass which is corvette specific,and fairly rare. There are thousands of 326 pumps out there but they were made for trucks and have a 3/4 inch bypass,and they need an adapter to use on a corvette. They didn't start to date code that pump until Nov 1965. Soooooooooo, if you have a non dated 326 pump,with the 1/2" bypass,you have the correct,and very possibly the original water pump. By the way the 1/2 inch is actually the inside diameter of the hose opening. I believe if you measure across the bypass hole in the top of the pump,it will measure 3/4",but that is the corvette pump.
Old May 7, 2008 | 08:37 AM
LSUvetteguy's Avatar
LSUvetteguy
St. Jude Donor '10
Old May 7, 2008 | 08:54 AM
ctjackster's Avatar
ctjackster
well-written piece on the 65 SHP water pump, and the dating issue that came into being (I think that there is still some question as to whether non-dated pumps were being installed well after Nov 65 though).
Old May 7, 2008 | 11:18 AM
RoadKing96's Avatar
RoadKing96
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
The full part number is 3859326 and I just wanted to add that I believe the front pulley mount should have only 4 holes and NOT the 8 that some reflect (other experts can chime in to correct if I am wrong)
The question I have is I notice that some have GM1, GM2,......GM8 etc near the part number 3859326. Is there some significance to which would be correct? I assume that the later GMx numbers were either over the counter replacements OR just came later...??
Are the GM1's for '63 GM2's for '64 etc...?
Old May 7, 2008 | 01:46 PM
macdarren's Avatar
macdarren
Okay, thanks for the information.
I will sort thru the pumps I have and see if any might be original or suitable as original replacements. My car is a very early 65, so probably as mentioned it won't have an actual date stamp. But if I have any extras that might be stamped a bit too late for my car or earlier unstamped I will hang on to them maybe offer them up as a pay it forward.
Darren
Old May 7, 2008 | 01:51 PM
JohnZ's Avatar
JohnZ
The GM1, GM2, etc. are foundry pattern numbers - doesn't mean anything relative to dates or usage. Water pump dates aren't checked in judging - they can't be seen with the pulley installed.
Old May 7, 2008 | 04:58 PM
Brumbach's Avatar
Brumbach
I've got my original waterpump from my 69 camaro SS 396. Unfortunately, I sold the car in 1971. Think I'll build the car around my waterpump. Anyone have the rest of my car?
To Water Pump question....
