bonding adhesive
Old May 6, 2008 | 10:10 PM
robburr's Avatar
robburr
Default bonding adhesive
restoring 66 convert can any one tell me a good brand of bonding adhesive to use
Old May 6, 2008 | 10:20 PM
nitromainia's Avatar
nitromainia
Vette Bond ...Fiberglass Evercote ....Great stuff!
Old May 7, 2008 | 07:55 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Depends on what you are bonding. I use diff compounds for diff applications. They each have their place.
Old May 7, 2008 | 08:42 AM
robburr's Avatar
robburr
i am bonding front fender bonding strips to hood souround is ecklers any good? it says the same as used at factory
Old May 7, 2008 | 09:02 AM
wombvette's Avatar
wombvette
Another consideration is who`s surround? Some later GM or aftermarket parts dont do well with standard polyester materials.
Old May 7, 2008 | 09:45 AM
64muscl's Avatar
64muscl
Default bonding
3m- Dynatron
Old May 7, 2008 | 02:34 PM
pda1964's Avatar
pda1964
Vette bond is great stuff but if you plan on using it be prepared to fork over some bucks. I just bought a quart for $47.00 last week, last year a quart was around $32.00. Paul.
Old May 7, 2008 | 03:12 PM
robburr's Avatar
robburr
i am using the oringal parts
Old May 7, 2008 | 05:49 PM
ragtopman's Avatar
ragtopman
St. Jude Donor '10-'11
3M 08115 works great.
Old May 7, 2008 | 06:40 PM
Midyearnut's Avatar
Midyearnut
Default Panel Adhesive
I'm with Ragtopman. Used 8115 to glue a surround, it was a piece of cake! Upside: Loooong working window (90 Minutes) which takes alot of stress out of the job. Downside: It's a bit pricey & at the time I used it the cartridges required a special 3M gun, VERY expensive! Fortunately I was able to borrow one. I've heard recently that the gun requirement has changed, hope that's true.
A couple of tips: whichever adhesive you buy, if it comes in tubes, overbuy, you can always return the unused tubes & before you pop open the tubes or start mixing a batch, measure, measure, measure whatever you're bonding. A few extra minutes before bonding may save you alot of time after the adhesive kicks.
Norton also makes/sells a product I'm told that's similar to 8115 but cheaper. I've never used it so I can't say good or bad.
Good Luck!, Bob L.
Old May 7, 2008 | 07:31 PM
DansYellow66's Avatar
DansYellow66
Yes, it's excellent. Has lots of body and looks like the old factory GM stuff and has a very slight amount of give to it after curing. Some of the aftermarket stuff I experimented with was too thin and creamy, too light of color and just didn't look original. The Ecklers stuff also dries dark gray which looks original. However, Ecklers is an epoxy material and will cook off fairly rapidly, depending upon how much hardner you put in it. So if working with something like a hood surround you might want to try one of the newer adhesives with longer working time. Someone once suggested keeping it in a refrigerator until just before using to slow down the set time.
Dan
Old May 7, 2008 | 11:07 PM
robburr's Avatar
robburr
thanks for the info i going to try ecklers i have chassis all done. going to start on body . Rob. B
Old May 8, 2008 | 07:07 AM
The Corvette Kid's Avatar
The Corvette Kid
Ecklers bonding adhesive is an excellant product. It does set up rather quickly so use during the coolest part of the day and don't add too much hardener. Bob
Old Jul 11, 2008 | 06:21 AM
Brumbach's Avatar
Brumbach
Dan
Are you referring to the Restoration Formula Panel Bonding Adhesive p/n 34266? What's the cure time?
Old Jul 11, 2008 | 09:47 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
WOW....
Member Paulywannafly sells and makes this stuff....Bottom of page...
http://www.thcorvetteshop.com/
Old Jul 11, 2008 | 10:09 PM
67vetteal's Avatar
67vetteal
We all tend to adjust our Hardener to the conditions presented by the weather. Hardener ratios are critical to the life of the Bond and the amount of shrinkage during the overall bonded period. Hopefully, the manufacturer recommends appropriate ratios. Stay within these guidelines whenever possible. Never ever use any Hardener that is more than a year old. Refrigerating Hardeners will extend the useful life of Hardener but fresh is better for quality results in the long run. Al W.
Old Jul 11, 2008 | 10:19 PM
Scott Marzahl's Avatar
Scott Marzahl
I don't believe Ecklers is an epoxy material as stated earlier since it uses MEKP for a catalyst. It's polyester resin based.
Old Jul 12, 2008 | 08:51 AM
uncle427's Avatar
uncle427
We have been using marine tex for over 30 years and have had excellent results in appearance, workability and zero shrinkage. It is a very expensive product and only available generally in marine supply stores and online. Comes in white or grey. Used it on all aftermarket press molded, hand laid, sermersheim and image noses and products. I would never consider using anything else. Probably around $80 a quart retail.
To bonding adhesive
