'59 Windshield Post problem
Old May 8, 2008 | 02:43 PM
PhilG's Avatar
PhilG
Default '59 Windshield Post problem
A few years ago, I had my windshield post tabs repaired by Grossmueller for $99. They were plated immediately and put on a shelf. Recently, I took all the windsheild parts to the only shop in St Louis that has experience assmbling the entire windsheild unit. As the shop owner screwed the lower channel to the tab, it broke off. He called me and together, we tried screwing the lower channel to the other tab. It promptly broke off also.
Has anyone else had a similar problem? The windsheild assembly is together now but both tabs are broken. Really aggravates me.
Old May 8, 2008 | 03:43 PM
Pilot Dan's Avatar
Pilot Dan
You don't say how they were repaired, but it sounds like the old piece was welded back on and the welds did not hold. That type of repair really does not work well on the pot metal posts. The better and stronger repair is a complete new replacement tab that I believe is attached with screws after your old post is prepped. Never did one, but I have heard good things about them. The repair is on the bottom side so no need to worry about the chrome. Good luck Pilot Dan
Old May 8, 2008 | 04:08 PM
SolidAxle's Avatar
SolidAxle
You can send them out and have them re-repaired without worry of chrome damage. Try Paul Mazut. I am not in the office right now so I don't have Paul's contact information. Perhaps someone else can provide. Paul does good work.
Old May 8, 2008 | 05:54 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Without messing up the chrome, they turn the post over...and work just on the bottom.
They machine a "keystone" like depression into the bottom of the post.
A metal piece.....shaped like a keystone on the under post area, and shaped like the real front of the WS post is then screwed into the recess using machine screws.
Ain't no way that system is breaking. Corvette Central does 'em.
Maybe others?
Chuck
Old May 8, 2008 | 09:59 PM
john neas's Avatar
john neas
Corvette Central has done the tab replacement for me on several cars. I am very pleased with the results.
Regards
Old May 9, 2008 | 10:45 AM
willy p's Avatar
willy p
7th Gear
Default Door Post.
Phil, Corvette Central did my sixty post years ago, good results. ***** P.
Old May 15, 2008 | 05:50 PM
vetteman64's Avatar
vetteman64
Paul Mazut 413-243-3439 (Massachusetts)
Old May 15, 2008 | 06:56 PM
Plastic Pig's Avatar
Plastic Pig
Live Free or Die
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
I believe Grossmueller's just sends them to CC.(at least thats what they did with mine) I've had no problems. Mine had fresh chrome with no tabs too, and they came back perfect.
To '59 Windshield Post problem
