Are tubes required?
Old Dec 17, 2001 | 12:26 PM
aobrien's Avatar
aobrien
Default Are tubes required?
I know, I know, not another tire question...
Well, I ordered my radials from Coker, then got to thinking. Am I going to need tubes with those new radials? I never really thought about it before, but I suppose that whether or not you need tubes depends on the rims that you are using. If I need tubes with the rims then I want new ones with the radials. I got a flat tire the other week and don't want that happening again.
Should I also order the tubes from Coker (if I need them) or will the tire shop have them?
[Modified by aobrien, 8:31 AM 12/17/2001]
Old Dec 17, 2001 | 12:31 PM
yooperod's Avatar
yooperod
Default Re: Are tubes required? (aobrien)
Any tire store should have Tubes for Radial tires.
Don't use regular ones.
rod
Old Dec 17, 2001 | 12:34 PM
JohnZ's Avatar
JohnZ
No need for tubes with them, unless you have leaky riveted rims; I have Cokers with welded rims on my '57, no problems. Thousands of cars were built in '55-'56 with riveted rims and tubeless tires and had no problems, although the change was made from riveted to welded early in '56 to eliminate any possibility of the rim being responsible for flat tires.
Old Dec 17, 2001 | 12:43 PM
aobrien's Avatar
aobrien
Default Re: Are tubes required? (yooperod)
Thanks fellas that relieves some of the stress. Those tires should be coming in late this week, just in time for Christmas. :D
My family is coming out from Denver and haven't seen the '58 in person yet. I can hardly wait.
Old Dec 17, 2001 | 02:09 PM
SWCDuke's Avatar
SWCDuke
It's best to NOT use tubes on radial tires, but if one is required it should be designed for the specific size radial you are using. Tubes are more likely to cause a sudden blowout if the tire is punctured.
If you have riveted wheels that leak, I think you're better off attempting to seal the leaks than use a tube.
Duke
Old Dec 17, 2001 | 03:52 PM
58Vette65's Avatar
58Vette65
WOW! A question I can answer. I just replaced 14" tube tires with 15" Cokers on my 58 and was a little disapointed in them. After reading threads about wheel alignment I had the car aligned, what a difference! Runs 70 MPH smooth as silk and straight as a arrow. We also bought steel welded rims from CC. two of them were painted gloss black and two of them were painted flat black.
To Are tubes required?
