Removing windshield reveal moulding - 65
Can't tell which one has the plastic handle...Is the one on the right the one that works?
Can't tell which one has the plastic handle...Is the one on the right the one that works? If so, where did you get it?
Bottomline...I'm trying to remove the entire frontend clip. I've got to get under the windshield reveal moulding to separate the clip from the windshield frame. I probably need to remove the w/s too to properly align the new clip. At the moment, can't get the dumb moulding off. Maybe I don't need to be too delicate. Suggestions????
The one on the left has a plastic handle. I have one of those. I stopped using it as soon as I cracked the roof glass in my Vista Cruiser trying to remove the window trim with the thing.
The left one is the bad one. I couldn't get it to work at all. The other one is all steel. I got it through a local parts store. As I told Rene-Paul all you have to do a print the photo and take it to your local parts store, they should be able to look it up. If that doesn't work, go to the local paint store. They can get it for sure.
Steve
Steve
Steve
I just got one from Eastwood.
Just finished a '63 SWC. Bought new clips from cc and after attempting to reinstall the trim we discovered that they are not the same as the originals. The replacements are just a bit shorter and will not allow the trim to snap back on correctly around the front windshield. Fortunately the originals were in good condition and we replaced the cc ones with originals and all went well.
Attn Buns; I believe that a 63 ONLY front moulding can be removed like the shop manual reads. The 63 moulding has a full flange on its inner perimeter. It is a stiff piece and will handle the prying, It is also a one year only piece that Piper has for 700 restored. So much for prying/praying. Mine came out ok after cutting the seal and removing the w/s. The side reveal mouldings have the same p/n in the 63/64 aim. It is just that clip in the side moulding that is a killer to find for the 63.
An alternative may be to use a 64 clip in the moulding and its mate on the w/s flange. [Screw on type].
brgds
rene
brgds
rene
#34
If you want to see how the 2 clips interact, RTFM (Read The Factory Manual). It's shown in diagram 12 at the top of page 1B-8 of my 66 Corvette Chassis Service manual. Molding removal is shown in figure 15 on 1B-9.
If it is not shown in the 63 manual or the 64-5 updates, let me know and I'll post the 66 pics.
#36
view a is close to the corner. it may be that only the corner has the clip 9b? The 9a clips [red] are indicated across the bottom. 2a is definitely the lower molding. The corner/vertical molding is called A on figure 12.
#40
Thanks Ron. I bought a wire tool from Eastwood, and I have the service manual. My biggest challenge is how to get the moulding off without damaging them!
