Sagging floor on 64 coupe
HI, I am a newbie with my first question. I have a 64 coupe, in which I recently installed an orginal shifter. While installing the shifter, I noticed that the driver's side floor was resting on the crossmember of the frame. An suggestions for lifting the floor? Thanks.
Received 1,859 Likes
This is the steel luggage stop panel (hidden under the carpet); if the rivets have loosened or pulled out of the floor pan, it needs to be repaired - fairly common problem on midyears.
