Paint formula
Old May 12, 2008 | 07:55 PM
Tonytz06's Avatar
Tonytz06
Default Paint formula
I know their has been a change from the original formula, but can some one tell me where I can get the paint formula for 1963 Sebring Silver?
Thank you
Tony
Old May 12, 2008 | 08:22 PM
GCD1962's Avatar
GCD1962
Thank you
Tony
The formula hasn't changed, but the tints to mix it have changed.
Old May 12, 2008 | 08:28 PM
harry miller's Avatar
harry miller
Default re.paint
941 ppg is agood match //
Old May 12, 2008 | 08:43 PM
67vetteal's Avatar
67vetteal
George, You may have answered my problem. I have a Lyndale Blue 67 Coupe. It was painted in lacquer base/clear 25 years ago. I'm trying to match it so that I can add a 427 hood. Mix by formula is too dark. Mix by Spectrograph matches formula mix perfectly. I've been perplexed as to how/why this occurs. It must be the Tints! My last resort is called a spray out. The mixing Tech. will attempt to tint the color to correct by eye. We'll see. Al W.
harry miller
Default re.paint
dbc 33389 code 1687 dmd 1682 1683 1607 624 646 prl 93 med. alu coarse a black violet wk.white gold pea these are the colors in the mix for two stage if you need the prophet fomula sheet let me know this color is a match if you have a orginal color chart//you can email me at chutcheon @aol///
Old May 12, 2008 | 09:10 PM
GCD1962's Avatar
GCD1962
Al, Sent you a PM
Old May 12, 2008 | 10:40 PM
Tonytz06's Avatar
Tonytz06
OK, thank you for the information.
Tony
Old Jul 20, 2017 | 08:53 AM
Dennis 613's Avatar
Dennis 613
I have a 64 Coupe satin silver metallic --paint 940 AA that I need the correct paint formula for, I've tried my local supplier ( Kunkle's ) with negative results.
Old Jul 20, 2017 | 12:12 PM
vettebuyer6369's Avatar
vettebuyer6369
Answering a post from over 9 years ago.
To Paint formula
