Correct speedometer readings
To determine the rear ratio, put the rear on jack stands. Put a piece of tape on the drive shaft and rotate the rear tires (by hand not under engine power) one complete revolution. Count the number of times the drive shaft turns over. Likely it will be in the lower 3:00's to 1. My car has 3:70's in it and the tach reads approximately 2700 rpm at 65 mph. Someone on this forum should be able to tell you what number tooth tranny gear to get for the rear end ratio that you come up with.
Putting the gear in is simple. Check the tail housing on the tranny. You should see the cable coming in from the speedometer head. Loosen the bolt that holds the head of the cable in and allow the keeper to rotate out of the way. Slide the cable end out and the gear that is presently in it should come out with the head. Slide that gear out of the cable head, replace it with the correct one, lube it up a little and reinstall it. Should be set to go from there.
The tach rpm sounds like it is reading correctly so I don't think there is any need to fool with it.
Good luck.
Steve
A Drive gear which is metal and is pressed into the transmission shaft. There are 2 of these: 1 for tall ratios and 1 for short ratios. I don't remember which rear end ratio gets which drive gear.
A Driven gear which is nylon and inserts into the side of the transmission.
The Driven gear is easy to replace. The metal Drive gear requires removal of the transmission.
Mixing the wrong Driven and Drive gears will result in a chewed up Driven gear. Guess how I know that...
Jeff,
Never heard of this!!! Not saying you are wrong but what would the difference be? I had to replace a plastic gear in my 1970 Nova SS. Original gears were 3:55 and the guy who owned it before I got installed a set of 4:11's. I simply found the correct plastic gear and installed it to correct the speedo. Would it be a difference between manufacturers? Muncie vs Borg Warner? I guess I need some education on this.
Steve
That avoids all the tire height problems you will cope with unless you have crusty old factory tires on the car.
ratio__tire size___drive gr_____driven gr_teeth_color
2.73__8.15-G70__3895494____3987918_18____brown
3.08__7.75 -15___3924098____3987918_18____brown
3.31__8.45-G70__3924098____3987919_19____natural
3.36__8.15-G70__3924098____3987920_20____blue
3.55__8.15-G70__3924098____3860344_21____red
3.70__8.15-G70__3924097____3860345_22____green
3.70__8.45-_____ 3924098____3860344_21____red
3.73__8.15-G70__3924097____3860345_22____green
3.73__F70______ 3924097____3860348_25____orange
4.10__8.15-G70__3924097____3860347_24____yellow
4.11__F70______ 3924097____3860348_25____orange
4.56__8.15-G70__3924097____3860345_22____green* uses 3890575 adapter
Here is a couple of the parts that you listed. They indicate that the same gear, driven and driver, use the same number of teeth, same tire size, etc. for 3:73 and 4:11 rear ratio. How does that work???
Steve
TECH BENCH
John Hinckley
Reader’s Question: I’m confused about speedo gear combinations for different axle ratios. When I bought my ’67, the speedo reading was way off (reads too fast), and the differential gears must have been changed; the stamping on the bottom of the (apparently-original by its date code) diff is “AL”, which is supposed to be 3.08:1, but marking the prop shaft and turning the wheels says it now has 3.55 gears in it. I can’t make sense of the “large-vs.-small” drive and driven speedo gears I’ve read about, and I need to know what I need to do to make it read properly; I removed the little plastic gear to check it, and it’s brown and has 18 teeth.
Response: It’s not unusual to find original diff housings with gear changes, and that’s apparently what you have. Here’s the story on speedo gears for ’63-’67 4-speeds and Powerglides.
Two different diameter 8-tooth steel speedo DRIVE gears were used, pressed on the output shaft, and each one used a different diameter “family” of nylon DRIVEN gears to accommodate a range of rear axle ratios.
The “large” DRIVE gear was 1.85” in diameter, and used the “small” (0.8” diameter) family of DRIVEN gears, as follows:
3.08 = 18-tooth, #3987918 (brown)
3.36 = 20-tooth, #3987920 (blue)
3.55 = 21-tooth, #3987921 (red)
3.70 = 22-tooth, #3987922 (silver)
The “small” DRIVE gear was 1.77” in diameter, and used the “large” (0.87” diameter) family of DRIVEN gears, as follows:
3.70 = 22-tooth, #3860345 (green)
4.11 = 24-tooth, #3860347 (yellow)
4.56 = 20-tooth, #3860329 (steel – used with special transmission with 6-tooth 1.77” diameter DRIVE gear)
For your 3.55:1 application, you need the #3987921 red 21-tooth DRIVEN gear in order for the speedo to read correctly. Fortunately, both your original and new axle ratios are within the same “large” DRIVE gear/”small” DRIVEN gear family, so a simple driven gear change will solve the problem. If one axle ratio had been in one family and the other axle ratio in the other family, you’d either need to change the pressed-on DRIVE gear to be able to use the correct DRIVEN gear, or you’d need to have a speedo shop make you up a ratio-adapter box.
The above assumes stock tire sizes (6.70-15 or 7.75-15) or replacements with the same diameter and tire revolutions per mile. For other tire sizes, you can also calculate the required tooth count for the driven gear; you’ll need to know tire revolutions per mile, which you can get from the tire manufacturer or develop as follows:
Tire Revs per Mile = 20168 divided by tire diameter in inches.
Once you have revs per mile, use this formula to derive driven gear tooth count:
DRIVE gear tooth count (8) x axle ratio x revs per mile, divided by 1001 = teeth.
(GM speedometers turn 1001 rpm at 60mph, or 1001 revolutions per mile)
Generally speaking, a 1-tooth change in the DRIVEN gear tooth count will result in a 5% change in the speedo reading (more teeth makes it read slower, less teeth makes it read faster).
’68-’70 4-speeds follow the same general gearing rules (although the DRIVE gears are nylon, retained on the output shaft by a spring clip), and ’71-up 4-speeds used ONLY the “large” DRIVE gear and “small” DRIVEN gear family; they used ratio adapter boxes for the limited number of 3.70 and higher (numerical) axle ratios offered.
Steve
year__ ratio_tire size____drive gear__driven gear_teeth_color
65-___2.73__8.15______unspecified__1359273_ 39____brown
67-___2.73__8.15______3895494____3987919_19 ____natural
68-___2.73__8.15-G70__3895494____3987918_18____brown
61-66_3.08__7.75-15___3924098____3987918_18____brown
67-68_3.08__7.75-15___3924098____3987919_19____natural
61-67_3.31__7.75______3924098____3987920_20 ____blue
67-68_3.31__8.45______3924098____3987919_19 ____natural
61-66_3.36__8.15-G70__3924098____3987920_20____blue
68-___3.36__8.15-G70__3924098____3987920_20____blue
67-___3.55__7.75______3924098____3860345_22 ____green
67-___3.55__8.15-G70__3924098____3860346_23____black
67-___3.55__8.15-G70__3924098____3860344_21____red
56-60_3.70_unspecified_unspecified__3708699 _22____green
61-64_3.70__7.75______3924097____3860345_22 ____green
67-___3.70__8.45-_____ 3924097____3860346_23____black
68-___3.70__8.45-_____ 3924098____3860344_21____red
67-68_3.73__8.15-G70__3924097____3860345_22____green
68-___3.73__F70______ 3924097____3860348_25____orange
67-___4.10__7.75______3924097____3860348_25 ____orange
68-___4.10__8.15-G70__3924097____3860347_24____yellow
56-60_4.11_unspecified_unspecified___370814 3_24____yellow
61-64_4.11__670-15____ 3924097____3860347_24____yellow
61-67_4.56__8.15-G70__3924097____3860329_20____steel
67-___4.56__7.75______3924097____3860344_21 ____red
68-___4.56__8.45______3924097____3860345_22 ____green uses 3890575 adapter
68-___4.56__8.15-G70__3924097____3860346_23____black uses 3890575 adapter
68-___4.89__8.15-G70__3924097____3860347_24____yellow uses 3890575 adapter
Speedometer Circle Gear
L6T steel: 1.92" OD (1963-70) 3845079
L7T steel: 1.76" OD (1963-70)
L8T steel: 1.76" OD (1963-70) 3708145
L7T steel: 1.84" OD (1963-70)
L8T steel: 1.84" OD (1963-70) 3708144
L8T natural nylon: 1.84" OD (1969-70) 6261794
NOTE: these SIX (6) gears have 30mm bore: used with 27 spline mainshaft.
L8T steel: 1.84" OD (1971-74) 3978758 NOTE: this ONE (1) gear has 35mm bore: used with 32 spline mainshaft.
Speedometer Circle Gear Retainer
used w/ nylon gear only (1969-70) 6261781
Speedometer Pencil Gear
L20T steel 3860329 3860329
NOTE: this ONE (1) gear used with 1.92" outside diameter circle gear.
L22T green nylon 3860345
L23T black nylon 3860346
L24T yellow nylon 3860347
L25T orange nylon 3860348
NOTE: these FOUR (4) gears used with 1.76" outside diameter circle gears.
L17T purple nylon 3987917
L18T brown nylon 3987918
L19T natural nylon 3987919
L20T blue nylon 3987920
L21T red nylon 3987921
L22T silver nylon 3987922
NOTE: these SIX (6) gears used with 1.84" outside diameter
Now all you need to know is the gear out back and the diameter of the tire, then you compute the driven gear.
I have or can get all these parts, most I have.
TECH BENCH
John Hinckley
Verle
Did you remove the bolt that retains the metal housing that contains the plastic gear?
Important - be sure to disconnect the speedo cable before removing the metal housing for the plastic gear, otherwise as you remove the metal housing the plastic gear may get pushed into, and fall in, the transmission case.
63's and 64's used the 429 tailhousing with the speedo on the driver's side, and '65-up used the 584 tailhousing with the speedo on the passenger side.
