PCV question
Old May 15, 2008 | 10:04 PM
6t5silver's Avatar
6t5silver
Default PCV question
My 65 327/300 has an edelbrock 1806 carb with performer RPM intake and mild edlebrock cam.
I'm adding a insulator gasket approx .320 thick to help with heat soak starting problems. To get more hood clearance I'm adding a drop down style base air cleaner.
I noticed that the previous owner has engineered the PCV sytem with a hoses coming out of the valve covers (LT1) style. One hose with pvc valve from the driver side valve cover attached to air cleaner base and the other is attached to pass. side valve cover and is connected to the power brake port ???? I don't have power brakes. Should this port plugged ?? My distributor is plugged into timed vacuum port and manifold port is not being used.
The pcv port at the front of the carb is capped, not being used. I have low vacuum 7" Could this be my low vacuum problem ??
Please advise. Thanks, Peter
Old May 15, 2008 | 10:15 PM
Procrastination Racing's Avatar
I'm not sure what you have set up, but it sounds like you have direct vacuum off the passenger side. That would be a source of low vacuum, because it is essentially open to the world.
A 327 block should have the rear draft connection near the oil pressure port by the distributor. This connects to the PCV system. Is this missing? Is it plugged? Do you have a non-327 block?
A few pictures would help everyone see what you have and give them an idea of how to fix it.
Old May 16, 2008 | 07:09 AM
6t5silver's Avatar
6t5silver
Its 327 870 block. The rear connection by the distributor is plugged.
I will try to post picture tonight.
Old May 16, 2008 | 08:20 PM
JohnZ's Avatar
JohnZ
Your system is "designed" (and I use the word loosely) BACKWARDS, and isn't doing anything. If you want to keep the same general scheme (and valve covers), the PCV valve goes in the driver's side valve cover, with a 3/8" hose to the large PCV port on the carburetor (the "exhaust" side of the system). The passenger side valve cover should have a grommet with an elbow connected to the base of the air cleaner (the "intake" side of the system).
Or, if you don't like the valve cover setup, you could use stock parts for the application, that will work - An oil fill tube from a '66 or '67 with a threaded bung in it for a PCV valve and a 3/8" hose to the PCV port on the carburetor, and the correct adapter tube assembly that goes in the vent hole in the back of the block and connects to the elbow in the air cleaner base with a large piece of rubber hose.
You should also have the vacuum advance line connected to full manifold vacuum, NOT "ported" or "timed" vacuum.
Old May 16, 2008 | 09:00 PM
6t5silver's Avatar
6t5silver
John,
I will probably chose option one. I believe you are right the system is connected backwards.
I would prefer to have option two, closer to stock but the edelbrock manifold does not have an oil filler tube.
Do you think my low vacuum problem is from this poor set-up ??
Old May 17, 2008 | 03:38 PM
JohnZ's Avatar
JohnZ
If it's actually connected as you described, "the other is attached to pass. side valve cover and is connected to the power brake port ????", you have a GIGANTIC vacuum leak, with manifold vacuum pulling crankcase fumes full time.
Option one should work fine for you.
Old May 17, 2008 | 11:55 PM
6t5silver's Avatar
6t5silver
I'm having a tough time to remove the elbow fitting from valve cover grommet. Any tricks. Do I have to remove the valve covers and push it from the inside out ?
Old May 18, 2008 | 09:31 PM
JohnZ's Avatar
JohnZ
The elbow should pull right out of the grommet unless it's some sort of non-stock arrangement.
Old May 19, 2008 | 08:55 PM
6t5silver's Avatar
6t5silver
John,
I removed the valve cover and the elbow had a barbed end and the grommet was rock hard. Cut it out ,replaced it PVC system is hooked up as per your suggestion and working fine
I also hooked -up my advance line to the manifold vacuum. Idle has increased to 1200rpm from 750. I adjusted the idle back to 750 and when I touch the throttle it goes back to 1200 stays for bit and decrease then increase. Initial Timing is 14 deg. at 750 rpm with vac. adv. unhooked and manifold port plugged.
I suspect I have to make a dist. can or springs adjustment. I read your posting on this topic. I understand the concept just not sure how go about it.
I took the car for spin and does start better respond better with manifold vac connected to the adv. line.
Any simple steps that a novice could try.
Peter
Old May 20, 2008 | 09:11 PM
avideo's Avatar
avideo
Default One Other Item...........
If you decide to go with a more "stock" type Edelbrock Intake Manifold with an oil fill tube; check out the EDL-2703 Intake Manifold. Good Luck!
To PCV question
