I was contacted from a friend who is an insurance adjuster. When he runs into the older vettes he always contacts us. He just called us last week about a 1958 corvette dual quad, numbers match, all parts their, no hit body, and solid frame. The guy started a frame off restoration, but now is divorced and selling the car. The car is in pieces. I can get this car really cheap. Are their any specific areas or parts to check for. I'm not a c1 guy yet i know alot, but right now have a (C2 and C3). What are specific things to look for. Any thoughts would be appreciated.
If cheap buy it then if you dont like it sell it and make money.
Since it's apart you have the luxury of checking everthing. Frame is key check for damage, rust etc. If your a numbers guy it is a great time to check them all. Wiring is key but again if it's apart replace it. Sounds like you will need to complete a parts inventory as well. These cars are pretty basic but you can a bundle on parts. Greg
I understand what vettebuyer5869 is saying, so I think it is more technically correct for model years '53 to mid 1960 to ask "do the numbers align with a reasonable assembly scenario"? Value clearly is placed on an engine block that is stamped with the correct configuration and assembly date, casting date and block casting numbers that align with the VIN and a frame stamp that reflects the correct VIN. The only numbers that you can't match are a VIN number to the same stamped on the block because they didn't start stamping VIN's on blocks until mid 1960 model year. So, to me the more numbers that "align" the higher the value. (assuming that the numbers on the stamp pad are original). My two cents.
Sounds like a great find!
You might want to call a local corvette club and ask someone to check it out for you.
Also, check the area under the dash for rust. Make sure all of the chrome is there. I know 58's had a lot of chrome compared to the other years. You might want to make an inventory and check to see what is missing.
i know they are not matching numbers(the block that is) but is the engine that came with the car. Is their any certain pieces of chrome to make sure too look for or any pieces?
The trunk Irons are a one year only item and are very pricey.
Price is easy decision if you really are getting it on an insiders deal. If there is any discrepancy on the VIN. be careful and diligent with your research. In their day these cars were very easy to play games with. Al W.
