1964 Vent Window Pivot Hinge
Old May 21, 2008 | 03:24 PM
slowjunk's Avatar
slowjunk
Default 1964 Vent Window Pivot Hinge
What tool is needed to install the rivet in the vent window pivot on a C2. The rivet needs to be peened over, how?
Old May 21, 2008 | 03:37 PM
Red63SW's Avatar
Red63SW
http://www.zip-products.com/Zip/prod...52C01293B2F3A5
It is a lot easier to do if the vent window assembly is out of the door.
Old May 21, 2008 | 07:52 PM
wenmaxjr's Avatar
wenmaxjr
Is this a coupe. I replaced the seals in my coupe this past winter. Yes they are much easier to do with the vent window removed from the car. I ordered one of the rivet tools from Zip Products but found it unsuitable to do a roll crip on a flat head tubular stainless steel rivet. I got a rivet tool with correct dies for that rivet. Not cheap for the tool ($175) but dies where $13 each.
To 1964 Vent Window Pivot Hinge
