LS2 engine
Old May 22, 2008 | 10:51 AM
lxwhite's Avatar
lxwhite
6th Gear
Default LS2 engine
objective is to install a LS2 engine into a '66 smallblock car with a Tremec 5 speed trans. The water pump interferes with uppr A arm. also oil pan touches the steering stablizer. Anyone with experience installing LS2 into a C2?
Old May 22, 2008 | 03:52 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There is a bunch of information in C3. Might not help with the stabilizer, but the chassis design is basically the same, the a-arms didn't move.
Old May 22, 2008 | 04:19 PM
mredi1's Avatar
mredi1
I had my 65 done, but used a Street Shops chassis, which had a mustang type rack and pinion. The water mump need the heater hose fittings pluged and moved to the top to get away from the interference. Here is my project thread - http://forums.corvetteforum.com/show....php?t=1590723
Street Shops modified the water pump for us. Good luch with your project. Tim
Old May 25, 2008 | 11:29 AM
90067's Avatar
90067
I have an LS2 in my 58.
To LS2 engine
