removing 67 engine / checklist
- Drain engine oil
- Remove hood
- Air cleaner
- Carb
- Alternator
- Fan
- FUEL PUMP (most will not clear with it on)
- Unhook exhaust. (I pull manifolds, but not needed).
- Distributor (a must), shields and wire guides (they could get bent)
- Oil Pressure Line
- Radiator and Shroud
- Starter wiring / Coil wires
- All hoses
- U-haul type packing blankets around nose and fenders.
If Trans is coming with it!!!
Shifter (Rods can stay, but they have to be tucked out of the way).
Unhook drive shaft or just let it slip off the spline (Oil will run out the end if yoke is not with the Trans.
Speedometer Cable
Pull the exhaust bracket at Trans mount
Loosen Trans mount bolts.
Some Don'ts
Support the engine with a jack under the oil pan (It will dent)
EVER get under or around the engine, assume it can fall.
Use cheep bolts and chains.
Get in a hurry.
Force anything.
Some Do's
Have a helper, two guys on the engine, one on the hoist jack.
Get an engine tilter, more so if the Trans is coming out also.
Have an engine stand or cradle ready to accept the engine.
Pick the engine near the lift boom, you may need to go high and my run out of stroke, no fun setting it back in to re adjust the chain.
I used a plate that bolted to the intake on the carb mounting surface. Those 4 little carb studs held just fine. (Made me nervous though).
Mark
I had never done an engine R & R until I used this book to do my 66 SB and then I later used it on my neighbor's 73 BB.
Of course, you will want a load leveler to allow you to tilt the engine as needed for the installation.
Hate to ask but can you point us to engine removal....
Last edited by RoadKing96; May 25, 2008 at 08:43 PM. Reason: To thank JohnZ for his confirmation note below
- Drain engine oil
- Remove hood
- Air cleaner
- Carb
- Alternator
- Fan
- Oil Pressure Line
- All hoses
Speedometer Cable
Some Don'ts
Get in a hurry.
Force anything.
Some Do's
Mark
#2 Disconnect battery
#3 Follow Mark's list
