Electrical problem to headlights
Old May 26, 2008 | 01:13 PM
Brucets11's Avatar
Brucets11
Default Electrical problem to headlights
Headlights quite working. I was able to trace the problem to the driver's side headlight. Taking loose the wire connector, I get voltage to both wires going to the headlight motor. Passenger side only has voltage to one wire at a time, depending on moving the switch to the up or down position.
I guess the two leads to the driver's side motor are touching together somehow. Any ideas on how this could happen? Somewhere the wire harness is worn?
Old May 26, 2008 | 02:16 PM
CaveCreekChump's Avatar
CaveCreekChump
Default If there is, in fact, a short...
...it might be time to think about replacing that particular harness before something else happens.
Old May 26, 2008 | 02:37 PM
Kensmith's Avatar
Kensmith
Check your black grounds first. Make sure they are not corroded and secure.
To Electrical problem to headlights
