WCFB Float Adjustment
In that position, the floats are not parallel to the air horn and the distance between the floats and the air horn varies between each ends of the floats. Should this adjustment be made in the middle of the float or at a different location?
Thanks..
Pierre
When inverted, the floats should be parallel (or very close to it) with the air horn. It's been a couple years since I've done a set but I don't remember that ever being a problem. I believe the measurment is 1/8" primary and 1/4" secondary. Be sure to adjust the floats both laterally and for drop.
Jim
On a WCFB, the floats should be adjusted in an inverted position to a near parallel position between the top of the float and the surface of the inverted top casting. The float drop is made with the top casting in a level position and the end of the floats about 3/4-inch from the bottom of the top casting measured vertically. An important point is to make sure that the floats are centered in their float bowls with the carb assembled. You don't want the floats to rub the sidewalls of the float bowls or they could stick open and cause a flooding condition and/or fire. I know this from personal experience. Adjusting the floats is done by carefully and deliberately bending the float supports and the tang behind the fuel inlet pintle. Good luck.
Pierre
http://members.capital.net/com/studiog/CarterWCFB/
Pierre
Some good info. on that site, some incorrect info. as well. WCFB = Will Carter Four Barrel
. It's actually an acronym for Wrought Cast Four Barrel.Jim
On Hemmings website, I read " Carter had been manufacturing the model WCFB four-barrel in the early Fifties, and General Motors began using the "William Carter Four Barrel" as standard equipment in 1952, with Packard picking this type of carburetor as its stock equipment choice in 1953, followed by Chrysler in 1954. These were popular with many original manufacturers; in fact, the WCFB series carburetors were used on Corvettes up to 1964. However, their weight, at over 17 pounds, suggested that a lighter carburetor with the same progressive four-barrel characteristics was needed."
See for yourself: http://www.hemmings.com/mus/stories/..._feature8.html
Hmmm, here's another reference: "Actually, the world's first progressive four-barrel down-draft carb was the Carter WCFB (Will Carter Four Barrel), introduced in 1952. Weighing in at a hefty 18 pounds, they were used on Buick Straight Eights. They are still available on E-Bay, from time to time."
That one's at this link:
http://www.442.com/oldsfaq/ofcrb.htm
There seems to be more than one opinion that WCFB means "William Carter Four Barrel".
The plot thickens.
- Pat
It makes sense that a Carter WCFB = Carter Wrought Cast Four Barrel and Carter AFB = Carter Aluminum Four Barrel.
Carter Will Carter Four Barrel seems crazy.
Jim
P.S. That Hemmings article is wrong. The WCFB was used through the 1965 model year. I've never found their articles all that accurate regardless of topic.
Finally, if you have them apart you may want to go ahead and install the "left-run, anti-stall" bushing if you can find one around.
Jim
"Sorry, everybody, it always has been, and always will be, directly from Carter, and yes, for the earliest Buicks and every thing else, WHITE CAST FOUR BARREL, period, end of the confusion.
Call Carter, ask for the in-house carb historian, he will confirm-WHITE CAST FOUR BARREL=WCFB."
Then at http://www.camaros.org/carb.shtml , we are told:
"In 1952, the "Will Carter Four Barrel" (WCFB) became the world’s first four-barrel carburetor and had a whopping rating of 385 CFM!"
So now we have 3 opinions:
WCFB-white cast four barrel
WCFB-wrought cast four barrel
WCFB-Will Carter four barrel
- Pat
The guys on those other forums can't even agree on Carters first name. Willard, William, Wilford.
Jim
I wouldn't be surprised if WCFB originally meant "wrought cast four barrel" or "white cast four barrel" and someone nicknamed it the "Will Carter four barrel" for reasons of nostalgia. Having said that though, my Google searches mainly turned up "William Carter Four Barrel".
- Pat
Whatever you choose to call it, they just get harder to find and more expen$ive.
I put all of my float settings exactly at the factory specs yet struggled with flooding, especially from the front carb. After checking and rechecking it dawned on me that the engine does not sit perfectly level in the car, thus neither do the carbs. Since fluids seek their own level, the slight front to back engine tilt was all that it took to cause the carbs to flood. After a bit of trial-and-error float adjusting I cured the flooding without affecting performance at WOT or other speeds.
Hope this helps!
Mike
Mine are set at 1/8" primary and 1/4" secondary and the level is exactly at the bottom of the float bowl site screws. I too blocked off my heat cross over and gutted the heat riser. No problem for 25 years. I've done at least a dozen set-ups exactly the same. Never a problem.
JohnZ - thanks for posting. I had never heard of the Will Carter theory until the other day. Wrought Cast has been the theory for a long time, but so has White Cast.
Jim
The gas should be at the screws lower hole level then there adjusted correct. That is the reason for the TWO driver side SCREWS
