clutch chatter
Old Jun 3, 2008 | 09:36 AM
64tux's Avatar
64tux
Default clutch chatter
last year everytime i pushed the clutch all the way to the floor i'd get this chattering going on. so i replaced the pilot bearing and it stopped. this year it's starting to do it again. i talked to a mech. in town and he said it needs some grease in the pilot bearing. says it's dry and that why it's chattering. what do you guys think??????? thanks, ray
Old Jun 3, 2008 | 10:04 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Is it a bronze bushing???? If it is, this bushing is permeated with a lubricant already and is not the problem.
Steve
Old Jun 3, 2008 | 10:39 AM
64tux's Avatar
64tux
Steve
i think it's a bronze bushing. but not sure. if it's not the problem, what is???
Old Jun 3, 2008 | 11:12 AM
MikeM's Avatar
MikeM
I've never heard an oilite pilot bearing (bushing) chatter. I've heard the bronze colored iron bushings squeal. They probably need grease. No, what they need is thrown away and replaced with the oilite bronze.
There's a lot of bushings on the market that are not oilite bronze.
NAPA sells an oilite bronze bushing. Maybe someone here has the part # as they handle both iron and bronze.
A "chatter" with the clutch all the way in sounds more like a pressure plate going bad. Or throwout bearing.
Old Jun 3, 2008 | 11:25 AM
66BlkBB's Avatar
66BlkBB
" A "chatter" with the clutch all the way in sounds more like a pressure plate going bad. Or throwout bearing. "
Old Jun 3, 2008 | 11:58 AM
64tux's Avatar
64tux
if thats the case, why did the chattering stop for a year when i changed the pilot bushing?
Old Jun 3, 2008 | 12:14 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Maybe a bent or damaged input shaft on the tranny which will destroy the pilot bushing in time, and won't do the clutch a bit of good either. When it was originally put together was the whole thing properly aligned with the bellhousing?
Old Jun 3, 2008 | 12:16 PM
66L72's Avatar
66L72
probably because you had the thing apart and back together again....reassembled to different torques etc and it took a while for the chatter to come back......... it happens
Old Jun 3, 2008 | 12:26 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Another thing that can happen is your pilot bushing could wear out because the bell housing is not centered on the engine.
You can dial in your bell if you have a magnetic dial indicator. You stick the mag base on the flywheel and the pointer on the inside circumference of the bell housing. I believe it has to be within .005" to be correct.
They make off-set dowels for this purpose. This happens very often with aftermarket bell housings, but it can be the case with stock one too.
Old Jun 3, 2008 | 01:04 PM
64tux's Avatar
64tux
when you put it together the bolts etc. only go in one place. how could you put it together not properly aligned?
i've put on around 7500 miles sinse i replaced pilot bushing. is it possible to wear out a bushing that fast??
Old Jun 3, 2008 | 01:06 PM
64tux's Avatar
64tux
thats a thought!!!!
Old Jun 3, 2008 | 01:11 PM
MikeM's Avatar
MikeM
Possible? Yes if you have something else screwed up besides one of those iron pilot bushings like a bellhousing out of alignment. Is there a pulsation in the clutch pedal you can feel?
[QUOTE=64tux; i've put on around 7500 miles sinse i replaced pilot bushing. is it possible to wear out a bushing that fast??[/QUOTE]
Old Jun 3, 2008 | 01:39 PM
64vettegal's Avatar
64vettegal
Mine was doing the exact same thing. I replaced the throwout bearing and the pilot bearing. While I was in there I put a new clutch in also. Fixed!!
Old Jun 3, 2008 | 02:22 PM
64tux's Avatar
64tux
no, no pulsation
the chatter is only when i put petal to the floor. and not every time. if i let the pedal up a little it stops
Old Jun 3, 2008 | 03:00 PM
claysmoker's Avatar
claysmoker
How far from the floor does the clutch start to engage when you lift the peddle? Might just be an adjustment issue if the pressure plate fingers/diaphragm are being depressed too far past the point where the clutch is engaged/disengaged. As the disc wears you need less throw to make it disengage.
Old Jun 3, 2008 | 04:01 PM
64tux's Avatar
64tux
about half way from the floor. i tried ajusting the pedal so it engaged closer to the floor but that didn't feel right. so i put it back like it was and the chatter seemed better (less often) than before. i'm going on the hotrod tour on thursday and worried things could get worse. don't know if i should tear into it before i go or worry about it after i get home?
Old Jun 3, 2008 | 04:12 PM
claysmoker's Avatar
claysmoker
How long has it been chattering? Can you live with not hammering the car and banging gears on the cruise? If you drive like a sane person and not like I do, it will probably live just fine. Do you have enough (1") free play at the top of the clutch stroke?
I might consider adjusting on it a bit myself, and if you can eliminate most or all of the chatter, then live with the poor engagement position until you can fix it properly.
To clutch chatter
Old Jun 3, 2008 | 05:17 PM
64tux's Avatar
64tux
thats just it. it's going to be hard not to hammer on it at least a little over 8 days. yes, i have play at the top. i've got two days to decide. last time i changed the pilot bushing and it stopped for a year. it's only a couple of hours of lying on the floor and wresling the trany. unless someone out there's got a better fix. i can't be the only one with a chattering clutch. does everyone just change everything???
Old Jun 3, 2008 | 05:43 PM
claysmoker's Avatar
claysmoker
You may as well since it's all on the floor.
Best of luck
Old Jun 3, 2008 | 05:57 PM
MikeM's Avatar
MikeM
I don't see any relationship between a bad pilot bushing and a clutch that releases halfway down with no problem but pushing it ALL THE WAY DOWN causes a noise (unless that bushing is totally wallered out. It shouldn't be at that few miles).
Therefore, it's my opinion that if you replace the pilot bushing and your problem ceases, at least for awhile, you're treating a symptom, not the cause.
Another one of my opinions is that your "chatter" won't cause you any problem on that tour if you don't shove the clutch pedal down far enough to cause the noise.
Just don't expect me to tow you in.
