Engine fires intermittently
Old Jun 7, 2008 | 04:41 PM
RREEVES's Avatar
RREEVES
Default Engine fires intermittently
Appears to be a fairly good spark from the high tension lead on the coil. But is it possible the coil could still be the problem. Also, what it the purpose of the ballast on the firewall.
Any help is always appreciated.........
Old Jun 7, 2008 | 04:59 PM
62Jeff's Avatar
62Jeff
The ballast reduces the current going to the points to keep them from burning up. When you start the car the ballast is bypassed to send full voltage.
It's not clear what problem you are trying to describe for your car, but if it starts and runs until you let go of the ignition key, then the problem is probably a bad ballast resistor.
Old Jun 7, 2008 | 05:01 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
I have had coils that were intermittent, but they usually act up more when hot.
Old Jun 7, 2008 | 05:31 PM
RREEVES's Avatar
RREEVES
Car starts, but runs poorly, since I have headers I can easily tell which cyclinders are firing.
Some are and some are not. This is the reason for thinking the coil could be bad. Is their a way to check with an ohmmeter.....
Old Jun 7, 2008 | 05:50 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
One of the last places I would look would be the coil - you could have a bad distributor cap/rotor, plug wires, flaky points, fouled plugs.
If its an intermittent problem then the ohm reading of the coil doesn't provide much - could be you measure it when its acting OK. Its simple enough to swap out after you check out the other areas.
Old Jun 7, 2008 | 05:57 PM
midyear1's Avatar
midyear1
Default Misfiring
First thing I would check is the pigtail wire from the distributor to the coil.
Old Jun 7, 2008 | 06:13 PM
67vetteal's Avatar
67vetteal
Play it safe. Do a Tune Up. Points and Condenser, Cap and Rotor and Plugs. Problem persists, change out the Ignition Wires. All Money well spent. Al W.
Old Jun 9, 2008 | 12:06 PM
RREEVES's Avatar
RREEVES
Thanks a ton for all the information guys...............
Old Jun 9, 2008 | 12:50 PM
Double-E's Avatar
Double-E
Have you ckecked distributor shaft end play? It may need to be shimmed.
Old Jun 10, 2008 | 12:43 PM
RREEVES's Avatar
RREEVES
How is this checked?
Old Jun 10, 2008 | 12:55 PM
Double-E's Avatar
Double-E
You have to pull the distributor out; at the bottom of the distributor above the driven gear, there are shims which control the spacing between the gear and the housing; put a feeler gage(gages) between the shims and the housing until you feel slight resistance; add -up all the gages used and this will be the clearance between the gear and the housing; check this number against the spec for your distributor; I believe this clearance should be between .001" to .007". If it is greater than .007", buy a shim kit from any of the parts suppliers and shim it to get into the range, the lower the better.
To Engine fires intermittently
