Edelbrock C4B Manifold
ALL small-block Chevy V-8's have the #1 wire tower and the point adjusting window oriented as shown in the photo above, and virtually all of them have vacuum advance units. If you're unable to set your timing correctly, you'll need to pull the distributor and re-orient the drive gear 180* on the shaft; that will give you an extra 13* of distributor housing rotation away from the #8 intake runner.
Certainly get help if you need it but after swapping intakes - 'stabbing' the distributor is the easy part of the job; even if you have to compensate for the performance manifold
1st page of this thread will not load for me...
Don't know if the problem is the computer I'm using or something else. ?
Intake manifold
Bill
My Edelbrock C3BX is straight off my '63 original motor and they are nice looking and some grind the Edelbrock logo off; the filler tube is in the right spot, original dizzy works fine with it and there is no stripped threads/broken ears. You can run a Carter AFB on it with manual choke just fine (I did for over a year).
Its a nice, lightweight, low profile, old school, dual plane that gives a nice performance boost but its not gonna add 70 hp to your stock mill. There is also no 'hot slot' under the carb to cause percolation and corrosion to your carb.
Does anybody know if the stock cast iron manifold is lower than the C4B?
I never thought to measure. Or is there an old style aluminum manifold than is lower
I can almost guarantee the cast iron manifold is shorter but I have no measurements to back it up. I don't know of another aftermarket manifold that'll even come close to giving you the hood clearance with the original WCFB/air cleaner combo. The eddybrock 3CB and related series are the lowest, aluminum, dual planes I found that would work on my car. I did run an AFB carb with it though - something to think about if its lower than the WCFB.
Thanks for responding
Then I took the car to my mechanic because I couldn't figure out the timing. He agreed there is a problem and couldn't adjust it by turning the distributer but it is in correctly. He suspects my balancer has slipped. It seems to start and run fine so I'll live with it. I really liked the looks of the aluminum manifold. Wasn't meant to be
It would be a really odd coincidence that your balancer slipped sufficiently to affect your timing concurrently with an intake swap. Possible, but I would double check everything else before rebuilding the balancer....
I'm having the windshield and dash pad replaced at Tony's Corvettes. I'll get them to look at it
Problems with timing and C4B intake
I ended up taking the C4B off and replacing it with the stock cast iron manifold that was on the car because it is about a 1/2" higher and the air cleaner was rubbing the hood. Then I tried the timing and couldn't find the mark. Starts, no backfiring, and purrs like a kitten.
I took my car to my mechanic and had him check the timing. He said everything was fine but he couldn't time it. TDC was on number one but when he tried to time it he couldn't see the mark. His guess was the balancer may be screwed up. The car runs fine so I said to leave it alone.
I now have the car at Tony's Corvettes in Gaithersburg, MD, for a new windshield and dash pad and several other little things and asked him to look at the timing. We'll see.
