62 - window / door post installation
I am about to install the door post, new felts, and window on my 62.
the previouse owner disassembled this so i do not know the order to install.
i was going to do trial and error but figured asking for help would save am soem time..
thanks in advance
mike
2. new felts into door post
3. install window, when the felts and the rest of the window trim pieces are in place next to impossible to get window in place. Don't hook it up, because you need to get your fingers on both sides of the window trim pieces for install
4. install window felts and make sure that the little tab (needle like) gets into door post felt casing. There is a slot or hole for it to go into. When mine were installed, we had to use a block of wood and beat them into proper position while they were on the door. With a fresh painted door it does make it a bit nerve racking.
5. Prior to putting the window felt in place I was advised to smash it with a hammer. I did that and it fit fine otherwise it is supposedly too tight.
I think I got that right, I recall having to do the trial and error thingy.....which can be frustrating, but then that come with the territory. Above is what I did for my '60, got to think it is the same
thank you for your help with this,
i install the driver side, but i think i made a mistake with #4
" 4. install window felts and make sure that the little tab (needle like) gets into door post felt casing. There is a slot or hole for it to go into. When mine were installed"
i did not know where the needle was supposed to go.
also i had to cut the replacment felts becasue they were too long (maybe that was my mistake)
see picture
I believe there are 2 different designs for window post/door felts.
One has the window post felts with a large diameter, and hollow, stainless bead that fits over the smaller stainless bead (needle) on the end of the door felts.
The other design has the door felts with a larger diameter and hollow stainless bead that fits over the smaller stainless bead on the window post felts.
Herb has a 60 model, I have a 62. I do not know if the different types of felt combinations were unique to a specific year.
Your picture looks like my 62 does.
If the other end of the felt seems a bit long then you might have to do that. And it might be, looking at your inside and outside trim, there is a gap in that joint as well......looks like it needs to move "towards the door post and the vertical joint to get smaller".......
my 2 cents....
