Question---sidepipe conversion
Old Jun 17, 2008 | 08:58 PM
chub's Avatar
chub
Default Question---sidepipe conversion
I have the exhaust system loose but can't break the sections loose to totally remove it. Anyone have a simple solution or should I just cut it?
Chub
Old Jun 17, 2008 | 10:05 PM
66BBDriver's Avatar
66BBDriver
Wounded Warrior Escort '11
St. Jude Donor '05
Heat---Put heat on the joints and twist them off, has always worked for me. Just be carefull don't burn your car down.
Bill Irwin's Avatar
Bill Irwin
Chub, if you're looking to keep them, try some PB Blaster, spray in the sections, rap a little with a hammer, spray again, rap, spray again and let it sit overnight. It't still stuck, cut. Bill.
Old Jun 17, 2008 | 10:45 PM
CaveCreekChump's Avatar
CaveCreekChump
Default I say CUT NOW!
Why save a bunch of used, rusty pipes that can be easily replaced?
Old Jun 18, 2008 | 05:51 AM
chub's Avatar
chub
Default thanks to all
It is stainless steel and I just thought it may be of some use to someone.
Thanks for the replies.
Chub
Old Jun 18, 2008 | 06:54 AM
6T7L71CPE's Avatar
6T7L71CPE
I leave the front pipe connected to the engine, disconnect the back hanger and wiggle, rotate, pull and curse the muffler as my feet are propped against the car somewhere. If the system is in good shape I'd hang on to it in case you want a break from the side pipes in a few years. I assume you have the rear panel off since it will be replaced, adds more working room. And, safety first when under the car manhandling parts. Good Luck
Old Jun 18, 2008 | 07:33 AM
MikeM's Avatar
MikeM
If it's a stainless system, it's worth saving.
If you don't have an acetylene torch to heat it, try laying a 2 X 4 against the muffler and see if you can drive the pipe off at the transmission joint. Leave it connected to the engine. It may work.
Eastwood sells a pipe separator. I've mever used one but it should work. I doubt the penetrating oil will do much good as it is the crimp on the pipe that is hard to separate, not rust.
Old Jun 18, 2008 | 10:12 AM
chub's Avatar
chub
thanks 6t7 and mikem I will try both suggestions.
Chub
To Question---sidepipe conversion
