Holy Cow! H pipe and new chassis dyno run
Numbers are RPM, w/ H pipe, w/o H pipe, at the rear wheels, through full exhaust, mufflers,and tail pipes, with 1.62" primary pipe Hedman headers
1500, 402, 225
1750, 400, 230
2000, 400, 300
2100, 405, 350
2250, 405, 340
2500, 405, 365,
2750, 405,380,
3000, 410, 400
3500 and up, they curves were pretty much parallel, peaking at 430 ft-lbs at 4300 RPM.
Doug
1500, 402, 225
1750, 400, 230
2000, 400, 300
2100, 405, 350
2250, 405, 340
2500, 405, 365,
2750, 405,380,
3000, 410, 400
Doug
Received 1,843 Likes
I read that as someone has stuck a potato in one of your exhaust pipes and the "H" lets the exhaust by-pass to the other side.
1500, 402, 225
1750, 400, 230
2000, 400, 300
2100, 405, 350
2250, 405, 340
2500, 405, 365,
2750, 405,380,
3000, 410, 400
Doug
1500, 402, 225
1750, 400, 230
2000, 400, 300
2100, 405, 350
2250, 405, 340
2500, 405, 365,
2750, 405,380,
3000, 410, 400
Doug
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
1500, 402, 225
1750, 400, 230
2000, 400, 300
2100, 405, 350
2250, 405, 340
2500, 405, 365,
2750, 405,380,
3000, 410, 400
Doug
1500, 402, 225
1750, 400, 230
2000, 400, 300
2100, 405, 350
2250, 405, 340
2500, 405, 365,
2750, 405,380,
3000, 410, 400
Doug
Am I reading you right? The "H" pipe actually makes 177 hp more at 1500 rpm, or is the 225 actually pound feet of torque? If not, these numbers are absolutely phenomenal.
Dave
Those numbers are ft-lbs torque, with H paipe and w/o H pipe (old dyno run) not HP.
No potato in the pipe.
There was always a strange harmonic in the exhaust, even before the full exhuast was added past the mufflers and even with the old 327, it dropped in torque some and the A/F ratio went real lean at 2200 RPM, no matter how much fuel you pulsed in at that RPM range.
Having to lean out the part throttle fuel in that 2200 RPM range now with the H pipe, as it is too rich.
I can't explain it. Maybe get rid of the resonators (which were added after the EFI, but before the new motor), they helped with the 2200 RPM anomolie but didn't completely solve it. The resonators mellowed the sound quite a bit before the H pipe as installed, they are halfway between the collectors and the mufflers and are basically 8" long, 4" diamater wide spots in the pipes, but with sharp inlet and outlet inside the resonator.
Doug
Doug
I am not sure what exactly happened except I heard tires scream for half a second, the front of the car lifted quite high (I still have SSM lift bars on),a nd the shift light went on at 5600 RPM faster than I could react,a nd I finally found second gear about 6500 RPM and shut it down.
The Mickey Thompson SR 26X10 tires did not spin very long, they hooked up quite nicely. Never made it to 50 MPH so fast in my life
Doug
C2 of Year Finalist (appearance mods) 2019
Having been around engines most of my life, I'd have to say you either had a clogged muffler or resonator or a kink in one side of your exhaust system to make that kind of a difference.
It is fact that "X" pipes actually perform better as far as increasing HP and TQ. An "H" pipe has some benefit, but it usually can't be felt in the seat of your pants.
The numbers you posted looks like you put a blower on it. I'd be looking at something being clogged, or get your money back from the guy that did your dyno.
The exhaust is all new within the past 2 years.
if there was a clog, we wouldn't have gotten identical 430 ft-lb torque numbers at 4300 RPM, with or without the H pipe, i don't think.
Same dyno, both runs, i was there for both.
Doug
The difference is there. Plug readings taken prior to H pipe install indicated both banks were equal (no restrictions of one bank over teh other.).
Doug
Mike: I think you are mis-interpreting my intention. I was agreeing with your analysis, and adding to it. My potato "blowing out" was to explain why the readings, with and without H-Pipe, were the same from 3500 RPM on up as AZDoug described. I am sorry for the confusion. Doug F.
Oh! I guess I didn't think anyone else would see it like I did.
....and heavy on the unbelievable! Something isn't koshier here, seems to me. Are sure about the numbers on the first run Doug?
...don't suppose the dyno operator could be funnin' you could he?
...whatever is going on, if it will work on anything else ...your in line for some big bucks! I've never seen numbers change that drastically on anything....ever.... especially at what might as well be at an idle.
Stan
Stan
Stan
Stan
Stan
Go back and re read my comments about the fuel pulse width and running too lean originally and couldn't get it rich enough in the ~2200 RPM range, and don't just focus on the raw numbers.
There is (was) some strange harmonic going on between the 1.62" headers and the Victor Jr intake in the low RPM ranges that the H pipe fixed. Same headers and same intake on both the 327 and the 427 and same weird ~2200 RPM problem, but the problem was worse on the larger motor.
Dyno from january 3, 2008:
Dyno from today:
Now look at the 327 Dynos, note the way high AF ratios, that were only brought into control by massive fuel added at ~2200 RPM, (and added fuel didn't help anything on teh 427 motor without teh H pipe).
Doug
Mebbe y'all with a bunch of dog motor cars should consider an H pipe.
Mine was same diameter as the 2.5" exhausts, and located about 7" behind the collector flanges.
Doug
