Interior glue problem
Old Jun 28, 2008 | 12:42 AM
ml1955's Avatar
ml1955
Default Interior glue problem
Anybody else had problems with upholstery spray glue not holding? I wipe the parts clean with a mild solvent / cleaner, glue according to instructions and it stays tacky at best. All my work is unraveling!!! Tried the stuff from Al Knoch and 3M... Help!
Old Jun 28, 2008 | 12:48 AM
54greg's Avatar
54greg
I used the al knoch glue. Not spray but in quart can and brushed on. Wow did it stick. The spray on 3m didn't stick so well.
Old Jun 28, 2008 | 05:34 AM
DansYellow66's Avatar
DansYellow66
I had to resort to brush on contact cement in a few areas.
Dan
Old Jun 28, 2008 | 07:55 AM
ren's Avatar
ren
I had the same problem. I ended up using carpet glue.It's thick and I applied it with a brush. You don't need alot. I went through about a can and a half for the whole car. In some case, I put some weight on the carpet(paint can) until the glue cured. Also, arpund the rocker panels, I used 1 X 2 wood trim and wood clamps to make a nice tight fit. Good Luck.
Old Jun 28, 2008 | 12:01 PM
ragtopman's Avatar
ragtopman
St. Jude Donor '10-'11
My experience with those spray upholstery glues is if you dont spray both parts, let it 'gas off' for 2 to 3 min. they wont stick and or stay very long.
As the glue is releasing the vapors and solvents(VOC's), by not letting it gas off, you have trapped the VOC's between the 2 pieces and hence, it comes back up.
Old Jun 28, 2008 | 01:44 PM
ml1955's Avatar
ml1955
I have sprayed both parts, allowed to tack dry and still it is like gum... When you resort to canned , brush on contact cement, do you have to remove all the old glue or did the conact cement work over the old glue?
Old Jun 28, 2008 | 02:14 PM
Woodie's Avatar
Woodie
Buy- Brand name "Stick-It" professional glue. works great
Old Jun 28, 2008 | 02:15 PM
54greg's Avatar
54greg
The brush on glue sticks to everything! I scraped with a putty knife vacuumed up loose debris and started spreading glue. Glue stuck great.
Old Jun 28, 2008 | 02:21 PM
1snake's Avatar
1snake
Throw away the spray cans and get out a brush. 1 coat of Weldwood contact cement will hold anything together.
Jim
To Interior glue problem
