? for Engine Builders
Old Jun 30, 2008 | 03:20 PM
TX63CONV's Avatar
TX63CONV
Default ? for Engine Builders
I am in the process of building a 327, nothing radical, hydraulic lifters. The instructions recommended spinning up the oil pump to prime the lifters. When I did, I got oil up through the pushrods on the driver’s side but not on the psgr side. I used a gm pump priming tool I borrowed from Autozone. Did my drill not have enough speed or is this indicative of another problem?
Old Jun 30, 2008 | 04:00 PM
MikeM's Avatar
MikeM
You didn't spin the pump long enough. Turn the engine in 1/4 turn increments while you spin the pump.
Old Jun 30, 2008 | 07:22 PM
oldschoolvette's Avatar
oldschoolvette
Old Jul 1, 2008 | 01:49 AM
buns's Avatar
buns
Did the priming tool look like this? You need the special tool that replicates the distributor lower housing to get oil to both sides of the engine.
Old Jul 1, 2008 | 09:15 AM
TX63CONV's Avatar
TX63CONV
tool looked exactly like that. Thanks for the advice on turning the engine quarter turn while spinning the pump.....
Old Jul 1, 2008 | 11:39 AM
Joel 67's Avatar
Joel 67
Just so there is no confusion, this is the correct tool to use. That fixture on the right of the primer is what Buns is talking about.
Old Jul 1, 2008 | 04:02 PM
TX63CONV's Avatar
TX63CONV
I just looked at the tool again and its the same. I tried mating it with the intake off but the distributor hole is recessed in the block once I set the manifold on it worked perfectly--or at least for one side.
Should I have a buddy turn the engine while I am spinning it OR turn the engine, spin the oil pump, turn the engine, etc.
Thanks everyone.
Old Jul 1, 2008 | 04:21 PM
buns's Avatar
buns
The tool in my picture has a set screw so you can adjust the height of the collar. If yours has this feature, I would compare the depth of the collar with the one on your distributor. If the groove doesn't line up with the oil hole, the oil can't get through.
Old Jul 1, 2008 | 04:40 PM
Powershift's Avatar
Powershift
Thanks everyone.
I would recommend to spin the oil pump, then turn the engine, then spin the oil pump, then turn the engine, etc. Do this until all the rockers have oil.
If you rotate the crank 180 degrees each time, and do this a total of four times (ie. one complete engine cycle), you should be more than ready for startup.
Larry
Old Jul 1, 2008 | 10:34 PM
TX63CONV's Avatar
TX63CONV
Thanks for the help everyone. Will let you know how it turns out this weekend.
To ? for Engine Builders
