plug wire clips
Old Jul 10, 2008 | 09:17 AM
bvetteman's Avatar
bvetteman
Default plug wire clips
need info on which bolts the plug wire clips fit on the oil pan.
thanks
Old Jul 10, 2008 | 09:27 AM
62Jeff's Avatar
62Jeff
Not sure it matters for your question, but what year are you asking about?
This picture of my 62 shows approximately where that clip should be, although you have to use your imagination to guess where the clip ended up
Old Jul 10, 2008 | 10:07 AM
Ironcross's Avatar
Ironcross
as close as I can recall near the middle, 'side center' of the oil pan would be the logical spot..
Old Jul 10, 2008 | 10:16 AM
bvetteman's Avatar
bvetteman
66 small block
Old Jul 10, 2008 | 04:43 PM
vark_wso's Avatar
vark_wso
Starting at the rear, count 4 screws forward on the LH side. This puts the U-clip near the area of the arc for the dipstick tube.
On the RH side, count 5 screws forward. Both locations have the U facing down. Both locations will turn out to be at the apex of the boomerang ignition shield. Install the heat shields, the U-clips, the wires for 2 & 4, then the RH boomerang before you install the starter.
Old Jul 10, 2008 | 08:57 PM
JohnZ's Avatar
JohnZ
They go on the pan bolt closest to the bottom of the V-shaped "boomerang" shields on each side.
To plug wire clips
