Brake Problem Still
Old Jul 12, 2008 | 08:58 PM
terrys61's Avatar
terrys61
Default Brake Problem Still
Had a post awhile back on my brakes(drum). Car was pulling to the left when braking. Checked tire pressure/adjusted the brakes but same thing. Decided to replace the hoses and the cylinders. Did that and bled the lines. Went for the test drive and left side locked-up hard when brakes were applied. After a couple of times of applying the brakes(and holding on to the steering wheel) it seemed normal when braking. Car stopped without pulling to the left or right When I went to take the car out for a drive it's been doing it again. When I apply the brake it pulls hard to the left. I do this a couple of times (apply the brake when moving) and it goes back to normal braking no problems. Any suggestions on this matter? Thanks
Old Jul 12, 2008 | 09:05 PM
L78racer's Avatar
L78racer
brakes that are adjusted too tight will pull, then they get hot and pull less.
just for the sake of diagnosis, try swapping the shoes only from right to left and see if it follows the shoes or if it's a hydraulics problem.
Old Jul 12, 2008 | 09:08 PM
MikeM's Avatar
MikeM
I'd say your right front wheel cylinder has a sticky piston(s).
Old Jul 12, 2008 | 09:20 PM
terrys61's Avatar
terrys61
I replaced both of the front wheel cylinders with new ones.
Old Jul 12, 2008 | 09:23 PM
terrys61's Avatar
terrys61
If I have them off again should I just go ahead and replace the shoes? The shoes didn't look that bad when I replaced the cylinder's so I left them alone.
Old Jul 12, 2008 | 09:59 PM
67L36Driver's Avatar
67L36Driver
My Corvair does that (first couple of cold stops) but I'm ready for it. It's likely adjusted a dab tighter on one side.
Old Jul 12, 2008 | 10:02 PM
terrys61's Avatar
terrys61
Guess I will try adjusting a little at a time on one side.
Old Jul 12, 2008 | 10:07 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Having just gone through this exercise I will tell you what I found.
I tried replacing all the wheel cylinders, but that didn't help. Then I took the drums in to have checked. 3 out of the 4 were fine, but one was out of round and that was the problem.
I had the 2 rear drums cut and the car now stops straight.
Old Jul 12, 2008 | 10:33 PM
L78racer's Avatar
L78racer
i would try swapping sides first. then you'll know. i've seen it happen before.
Old Jul 13, 2008 | 09:55 AM
terrys61's Avatar
terrys61
Ok, did the swap of the shoes this morning. Was pulling to the left when cold, and then back to normal after a few minutes of driving. After I did the swap the vehicle now pulls to the right when cold. Would this be a shoe problem? Thats the only thing I changed.
Old Jul 13, 2008 | 10:15 AM
L78racer's Avatar
L78racer
i would say yes. the shoes could be contaminated or if they were relined shoes, the material may be different between the two sets. it actually could be a problem with the shoes that aren't grabbing. they are just "different" than the other side.
get a premium brand shoe. new- not relined. Wagner works for me.
also be sure you have them installed correctly. the primary (front half) have less lining material than the secondary (rear half) at each wheel.
MikeM's Avatar
MikeM
Yes. Good advice you got. Chenge the shoes. Both sides.
[QUOTE=terrys61; Would this be a shoe problem? Thats the only thing I changed.[/QUOTE]
Old Jul 13, 2008 | 10:26 AM
terrys61's Avatar
terrys61
Just to make sure, the lesser of the lining would go to the front. With the most to the rear. Is this correct.
Old Jul 13, 2008 | 10:36 AM
MikeM's Avatar
MikeM
Yes.
Old Jul 13, 2008 | 10:39 AM
terrys61's Avatar
terrys61
Yes.
Thanks for the help. Terry
Old Jul 14, 2008 | 12:12 AM
Pilot Dan's Avatar
Pilot Dan
You did not mention if you had all the drums turned or not. An out of round drum will pull. It will also give you an uneven brake adjustment at the offending wheel. Check the drums. Pilot Dan
To Brake Problem Still
