$20 and $25 a piece for these condensors that go on the cluster and various areas under the dash. Mine appear to be original and I believe they are shot.
So, while I have the dash and all out, I want to replace them, but I am not in the mood to spend $200 to do it. I gotta believe these are generic type condensors and can be had somewhere for a few bucks a piece. I'm not interested in "correct", But I am interested in the proper "condensing" (Mfd, I believe it is) as it were.
I'm sure some of you guys have made the cluster repair and have run into this. Where did you buy your condensors? How did you determine the size of the condensors, etc???
I tossed mine. Didn't see the need to replace them with anything, as they are simply shock aborbers to smooth out generator induced electrical noise and make the radio sound a bit better. if you have an alternator, they would seem to be moot due to the alternator slip rings in lieu of the sparky generator commutator.
If you buy them from newark electric, or such, they are called capacitors. Dunno their microfarad ratings.
Just generator noise huh??? I thought they were on the turn signal/flasher/ammeter etc. because of the surge noise they made? Good deal, If I don't have to by them at all, great! I just didn't want to get it all together and find out I have to pull the cluster back out.
On a car such as yours:
1) A condensor on the Amp gauge for engine noise (I think)
2) A condensor on the brake light switch to mute static from applying the brakes
3) A condensor in the parking brake alarm circuit so that flashing on/off BRAKE light doesn't make noise
4) A condensor in the flasher circuit so the blinkers don't make noise on the radio
Plus one or two others that I can't think of right now.
There's two on the top backside of the cluster as well, (of course they weren't hooked up) but I can't locate them in the AIM. Do you know of a size or capacitance they should be, or where I might find this info? I'm currently rumaging through Nolands book for any info.
I'm afraid I do not know.
The one on the top rear of the cluster near the tach, is probably spliced into the tan parking brake wire. My 65 didn't have any others mounted high up in the cluster, just the one under the Oil gauge that plugged into an always-hot brown wire, and the one under the Amp gauge that connected to the Amp wiring.
I'm looking at photos on Long Island Corvette's web site. Their capacitors have numbers on the end. Do you see any numbers on the ends of yours that may indicate their rating?
What AZDoug told you about the function of "condensors" is accurate ..... they dampen Voltage transients.
The capacitance is not critical. Anything from about .2 MFd to, oh, 1 MFd will work.
What you want to also consider is the Voltage rating since automotive electric systems can have some huge Voltage transients.... significantly more than the 14.4 Volts you measure at the generator.
I'd look for capacitors with a minimum of 100 Volt rating and higher is better.
I'd also look for non-polarized capacitors (you don't have to think about which wire is positive.... just hook it up) and I'd avoid a type of capacitor known as an "electrolytic".
As long as you don't need "correct", a well stocked Radio Shack will have capacitors that will work just fine.
Great, Thanks guys. I have located them in U69 and in the Adams book. They appear to the same as the P/N's are sequential, except for a couple of them.
HeavyJetPilot...LIC is where I found the $20-$25 per price tags. Did they have a generic source outside of the catalog that you were thinking of?
Anyway, I got all the infomation I was looking for from you all, Thanks Again
