Flaming River steering column
Because of my problems with the turn signal switch in my Corvette, I'm contemplating purchasing a Flaming River or Ididit steering column...
According to the Ididit site some modifications are required to your existing steering column to accomodate the Ididit unit....
http://www.ididitinc.com/retrofit_co...rvette_oh.html
53-62 Corvette
Due to lack of space in front of the dash this column is only available in a straight version. The original under-dash mount will be used and you will be required to fabricate your own floor mount. There is a solid shaft that extends from inside the gearbox to the steering wheel. This shaft will need to be cut and modified to fit a coupler. Your original wheel or an aftermarket wheel can be used. Although, a new adapter will be required.
I could not find any similar info at the Flaming River site, so I sent them an e-mail asking....
This is the reply I got back....
Has any regulars installed a FR column with the stock 53-62 front suspension?
Cheers
Ken
53-62 Corvette
Dear Ken,
The column is a direct bolt in column with the exception of the
wiring,however, we also offer the female side of the column's wiring
plug,that will allow you to transfer the stock wiring over to this
adapter, and then plug into the column.
Best Regards,
Tech Dept.
Flaming River Ind.
800-648-8022
Best Regards,
Tech Dept.
Flaming River Ind.
800-648-8022
Cheers
Ken
Received 1,859 Likes
<<Quote:
Dear Ken,
Best Regards,
Tech Dept.
Flaming River Ind.
800-648-8022>>
That's hogwash - apparently they didn't understand that you're talking about a C1. Their column requires exactly the same kind of rework/fabrication as the Ididit column.
Dear Ken,
Best Regards,
Tech Dept.
Flaming River Ind.
800-648-8022>>
And since you have a 1960 model, your VIN tag may be spot-welded to your steering column (depending on when your car was produced) so you may have to deal with relocating your VIN tag to the new column.
St. Jude Donor '07
Bill
Ken,
Note that for replacement of the column, if keeping the stock C1 steering box, the column does not need to be as short as shown in wmf62's picture. His column is much shorter since he was converting to a "modern" rack & pinion system. And in fact, his could of been several inches longer (as seen in his picture, you can see the straight coupling and splined shaft extension that was added).
However, to change a steering column due to a problem with the turn signals seems somewhat extreme. Yes, it solves the problem, but at what cost? I know wmf62 had to purchase several other items to make it work (couplings & u-joints, shaft, adapter for steering wheel, wiring "kit"). With the stock steering box, you not need the u-joint, but most of the other "stuff" would be needed.
Now if you were planning on replacing the steering box with something "better", then a new column makes more sense.
I to am surprised that someone has not come up with a better turn signal switch for the C1's. But I do fault the switch as well, since the need to return to exact center (or the both brakes lights will not be lit) is a big part of the problem (along with the cam and levers).
Plasticman
Plasticman
St. Jude Donor '07
Ken,
Note that for replacement of the column, if keeping the stock C1 steering box, the column does not need to be as short as shown in wmf62's picture. His column is much shorter since he was converting to a "modern" rack & pinion system. And in fact, his could of been several inches longer (as seen in his picture, you can see the straight coupling and splined shaft extension that was added).Plasticman
the Ididit 58 - 62 C1 column only comes in one length.
Bill
Do you have an old switch/cam for a pattern? Any suggestions for improvement? This isn't a problem. I have prototyping and small run capabilities.
A better turn signal system would put me in seven-heaven... On the weekend with the assistance of my kid brother (30 years as a mechanic) we took alot of play out of my 60 using the ST12 manual... However we did not have time to drop the pitman arm as per ST12...
Now it's pretty tight and responsive now.. Not as tight or responsive as my 2000 Impala but what a difference... Best she's ever been in the 25 years I've owned her...
I've requested Flaming River provide me with an electronic version of their installation instructions as they are adamant it is a simple bolt in which seems to be in conflict with the good people here... AND I trust the word of my fellow CorvetteForum members more then any vendor when it comes to C1/C2 knowledge...
Cheers
Kenmo
Cheers
Kenmo
OK, but does the Flaming River come in different lengths?
And, if the Ididit is billed as a replacement for 58-62 Vettes, then why would it be so short (and not reach closer to the steering box)?
John
John
I really like doing business with FR, but their C1 column was too ugly for words. They kept telling me that they were going to make a column with a bell end that was closer in looks to an original one, but as far as I know thay have not yet done so.
Regards, John McGraw
Just received an updated e-mail from Flaming River...
Dear Ken,
Sorry, to take so long replying back to you.
Our column is 33" long in length, however,as far as the installation of
the column goes, yes, the long shaft coming up from the steering box
does need to be cut, and a u-joint installed in order to connect the
column to the existing steering.
The column will accept the stock steering wheel,and hub though, without
an adapter being necessary.
So,in closing, we apologize for for misleading you to think that the
column is a direct replacement column!
Best Regards,
Tech Dept.
Flaming River Ind.
800-648-8022
Dear Ken,
Best Regards,
Tech Dept.
Flaming River Ind.
800-648-8022
Ken,
I would also expect that the existing shaft coming from the steering box not only needs to be cut off, but also need to add either splines or flats (double "D" or single "D") for mating to the U-joint.
Then there is the potential issue of adding an upper bearing and sealing the tube off (at the cut off steering box tube, where the shaft exits the box). I can't see just leaving that shaft floating and the tube unsealed. If the shaft was cut short, I could see not needing another bearing, but if the column is short, then the steering box shaft will be long, and might need another bearing to support it @ the upper end.
Plasticman
Plasticman
I've decided not to go the Ididit or Flaming River route... I've ordered a few things from CC to fix my turn signal light problem..
I really wish someone sold an updated signal switch with hazzard lights...
Cheers
Ken
Cheers
Ken
St. Jude Donor '07
i don't believe the Ididit column is touted as a 'replacement' per se, only that it is the same style as the original. their Classic Straight column is the same style/look as the C1 column and i think a much better choice as the wires come out of the column in the middle of the bottom, just like my original does. it does come in various lengths, but the longest Classic 'stock' length seems to be 35" (i don't know offhand what the length of mine is). and as John McGraw said, they will make a custom length; we didn't know how the new intermediate shaft was going to run, so we had to add a coupling and a 6" spacer shaft. had i known beforehand, i would have had a 6" longer column made...
all things considered, i think we did one hell of a fine job..
Bill
