327 Block
Old Aug 6, 2008 | 01:46 PM
mrruffhouser's Avatar
mrruffhouser
Default 327 Block
I'm trying to identify a 327 block with a casting number of #3959512.
Can anyone help me to ID it?
Old Aug 6, 2008 | 01:54 PM
Scott Marzahl's Avatar
Scott Marzahl
Yes, it is a CE block or replacement chevrolet engine. Sometimes referred to as counter replacements, crate engines etc. It could have been a warranty replacement or across the counter purchase.
Old Aug 6, 2008 | 03:56 PM
mrruffhouser
Thanks, That helps. It has no serial number-the pad is unmarked. So I don't know much about it like cam shaft, pistons, etc. Any ideas?
Thanks again for your help.
Roger
Old Aug 6, 2008 | 04:03 PM
Scott Marzahl
No idea what is inside, could be anything. What do the pistons look like, any heads on it?
Old Aug 9, 2008 | 10:21 AM
mrruffhouser
The engine was built up with fuelie 2.02 heads, and solids. I don't know what cam is in it and don't what to take it apart to find out. When the lead was taken out of gas, I put 1.96 heads one it that were set up for unleaded gas. It's getting time to adjust valve clearance and am looking for advice on recommended clearance. Anyone have advice?
Old Aug 9, 2008 | 01:24 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Anywhere from .018 and .022 to .030 and .030. Check and see where they are then go from there. When you are done it should sound like a finely tuned sewing machine(if that makes any sense). I love that sound !!
To 327 Block
