Help on info for 1962 windshield assy.
I am reassembling the windshield frame on my 1962 Vette. The question I have is on the upper frame to header molding. Should the upper molding fit over the header molding and over lap the lower edge of upper frame on both sides or just one side?
When I took the frame apart only the forward edge of the upper windshield molding was attached under the upper frame. Is this correct?
Thanks that answers my last question.
New question? To install the steel upper windshield frame inside the stainless upper molding do you slide it in from one end thru to the other? The bends on the frame look awful tight to go thru the stainless outer molding.
I'm in the midst of doing my 59 windshield and dash pad. I think that the windshields (59/62) are much the same for your year. To answer your first question I don't believe that the front of the chrome molding( outside of the car) fits over the frame in the same manner as it does on the back side (inside of the car). The outside seems to fit better, into a small valley in the weather strip. The inside part kind of ends up where it does. As to fitting the molding onto the frame, it's kind of like putting a broomstick into an inner tube. I did it by centering the molding onto the frame then working the frame into the molding. It doesn't look like it will go but with a little effort, it will. One word of caution, make sure everything, ie molding, frame pieces,chrome trim, etc are dead nuts centered, otherwise you'll be taking it off a few times to recenter. Also use plenty of soapy water to facilitate putting the glass into the w/s and frame. Don't want to crack a $500 item.
Steve
Steve
Steve
Steve
