c-2 visor install problem
Old Aug 11, 2008 | 02:47 PM
Trkdrvr's Avatar
Trkdrvr
Default c-2 visor install problem
Hi folks: i'm trying to install new visors and the supports are very loose and the screw/receivernut doesn't reach so they can be screwed together. It would seem that I have to squeeze it together but i don't want to mess it up. Anyone done this recently? All help appreciated.
Old Aug 11, 2008 | 03:36 PM
Mr D.'s Avatar
Mr D.
I installed a new set of visors yesterday using new screws and receiver nut. I took a small drill and cleaned out the holes and was able to get the the two started and than tighten from there.
One thought would be to use a longer screw and nut with small washers to pull the metal in a little without the worry of damaging the material.
