it's function is to stay closed off when the car is cold to redirect the passenger side exhaust thru the intake manifold crossover passages to help speed up the warm-up process of the motor.
Once the exhaust gases warm up the bimetal coil spring on the heat riser it allows it to open up and the exhaust gases now pass normally thru the exhaust system on that side.
If you don't drive the car in the winter you can easily do without it. I took it off my '65 and replaced it with the available spacer unit as did many others on the forum.
If you want to take your car thru NCRS judging though they will deduct if it's missing
this is the heat riser here, next to my exhaust manifold
my '64 had it and the car when cold wouldn't run worth a damn, but when I got the side exhaust on the car and did away with that thing, it idles GREAT and runs great all the time.....of course I don't drive it in the winter, so it makes no sense to have it...by the way it is a 327/365hp motor and runs much stronger since I put the side exhaust on as well....
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
I've read some where in here, that if your going to be judged just remove the flap, leaving all the 'appearances' of having a correct heat riser. It also eliminates the possibilities of sticking closed.
RK
depends I suppose. They do check proper operation of the heat riser during PV (Performance Verification) testing. During regular judging they probably wouldn't catch it.
doug,
Unless you drive the car in cold weather, I recommend you use some wire to keep the riser in the open position. On my 67 I had a lot of problems with hot starts and fuel percolation in the carb bowls with today's gas. All this went away when i wired it open. Thanks to SWC Duke for the tip.
RK
Exhaust flow from the tailpipes during cold-start is checked during the "Operations" portion of Flight Judging, so removal of the flap ("gutting" the heat riser) will result in a 25-point deduction. Just wire it open and remove the wire for judging.
