valve adjustment
Old Aug 17, 2008 | 03:58 PM
Fast66vette's Avatar
Fast66vette
Default valve adjustment
Which ones are the intake and exhaust valves on small chevy heads?
Old Aug 17, 2008 | 04:03 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
just check the location of each valve in relationship to the intake manifold runners and the exhaust manifold ports. each valve lines up with it's respective intake or exhaust port.
Bill
Old Aug 17, 2008 | 04:08 PM
Dave Tracy's Avatar
Dave Tracy
Bill
That's it!
Old Aug 17, 2008 | 05:18 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Which valves are which ???
Just remember--front to back or back to front:
E-I-I-E-E-I-I-E
RON
Old Aug 17, 2008 | 06:46 PM
ghoastrider1's Avatar
ghoastrider1
ifs its hyd vlaves, it doesnt matter in the adjustment. They are all the same.
Old Aug 18, 2008 | 03:13 PM
JohnZ's Avatar
JohnZ
Yes, it matters, or you won't have the correct lifters on the cam's base circle when you do the adjustment. The adjustment METHOD is the same on each valve, but you have to know which ones are the intakes and exhausts when you position the crank to make the adjustment.
To valve adjustment
