Battery Tender Plus question
Old Aug 26, 2008 | 02:30 PM
Stick's Avatar
Stick
Default Battery Tender Plus question
I use a Battery Tender Plus on my swc and leave it hooked up whenever it is in the garage. I've been wondering if that's the best idea because of the self-winding clock stopping and the circuit overloading. The option would be to just use it once a month to refresh (as JohnZ suggested the other day) or to use the cutoff and hook up the battery only. Any thoughts?
Old Aug 26, 2008 | 03:06 PM
stingrayl76's Avatar
stingrayl76
Depends greatly on how much you drive the swc. I would think if you drove it on a weekly basis, you wouldn't need the battery tender. Depending of course, on how far you drove it.
On the other hand, if it sits for long periods of time, I would disconnect the battery and hook up the battery tender. Just as a safety precaution, after driving my Vette and parking it in the garage, I disconnect my battery via the "green ****". The clock never has the correct time, but who cares! Guess I could fix that problem with a fused bypass around the battery disconnect.
Old Aug 26, 2008 | 06:51 PM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
Also think it is best to only charge after extended periods and not necessary to use a battery tender. If you have the green **** disconnecting is best for extended periods.
My car now has a 7 yrs old battery and sits all Winter long. Fires right up in the Spring as long as I had the battery disconnected via the green ****.
Old Aug 26, 2008 | 07:00 PM
JohnZ's Avatar
JohnZ
That was related to 6-month winter storage; during the driving season, I don't use the "Battery Tender" at all - not necessary.
To Battery Tender Plus question
